[GRASS-user] (Linux) WXGUI not launching command windows in Fluxbox
Tomáš Brunclík brunclik at atlas.cz
Mon Apr 10 01:56:58 PDT 2017
Update: I just tried with Fluxbox running inside MATE instead of its
default Marco window manager, with the same results as running bare
Fluxbox. Maybe it is Fluxbox specific? (Fluxbox 1.3.5)
Tomas B
Tomáš Brunclík napsal(a):
> Hello all,
> I just encountered strange wxgui behaviour (Linux 64bit, GRASS
> 7.2.1svn r70326 binary snapshot):
> When I run it from MATE desktop environment, everything works normally.
> When I run it from Fluxbox, wxgui starts, I can select location and
> mapset, the main program starts normally. But then, selecting (almost)
> any interactive command from menu, i.e. v.info or g.region, nothing
> happens. Also, when I try to run the same command without parameters
> from the console within the layer manager window, nothing happens,
> nothing shows in the console log file if I activate it. When I try to
> run the same command from the terminal emulator window running in the
> GRASS session, it normally launches the v.info window. Very few
> actions do open a window from menu, so far I discovered g.gui.gcp,
> "Add more raster or vector maps (Ctrl-Shift-L)" and "Run script" in
> File menu and panel icons working (translation of menu items from Czech).
> Selecting a non-interactive menu item, or putting it in the console,
> like g.region -p ( menu "Settings/Region/Show whole region (g.region
> -p)" ), the command works and shows its output in the output pane of
> the console tab.
> Can anyone reproduce this? Is it normal, i.e. does the wxgui need some
> service not running in a bare linux window manager, which is running
> in a typical full desktop environment?
> Regards,
> Tomas Brunclik
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
