[GRASS-user] (Linux) WXGUI not launching command windows in Fluxbox
    Tomáš Brunclík
    brunclik at atlas.cz
    Mon Apr 10 02:18:48 PDT 2017
Update2: Everything works in Blackbox WM, so it is either issue of
Fluxbox, or my configuration of it. Still, it would be interesting if
some Fluxbox enthusiast would test it. Probably not worth to bother for
others..
Tomas B.
Tomáš Brunclík napsal(a):
> Update: I just tried with Fluxbox running inside MATE instead of its
> default Marco window manager, with the same results as running bare
> Fluxbox. Maybe it is Fluxbox specific? (Fluxbox 1.3.5)
> Tomas B
>> Hello all,
>> I just encountered strange wxgui behaviour (Linux 64bit, GRASS
>> 7.2.1svn r70326 binary snapshot):
>> When I run it from MATE desktop environment, everything works normally.
>> When I run it from Fluxbox, wxgui starts, I can select location and
>> mapset, the main program starts normally. But then, selecting
>> (almost) any interactive command from menu, i.e. v.info or g.region,
>> nothing happens. Also, when I try to run the same command without
>> parameters from the console within the layer manager window, nothing
>> happens, nothing shows in the console log file if I activate it. When
>> I try to run the same command from the terminal emulator window
>> running in the GRASS session, it normally launches the v.info window.
>> Very few actions do open a window from menu, so far I discovered
>> g.gui.gcp, "Add more raster or vector maps (Ctrl-Shift-L)" and "Run
>> script" in File menu and panel icons working (translation of menu
>> items from Czech).
>> Selecting a non-interactive menu item, or putting it in the console,
>> like g.region -p ( menu "Settings/Region/Show whole region (g.region
>> -p)" ), the command works and shows its output in the output pane of
>> the console tab.
>> Can anyone reproduce this? Is it normal, i.e. does the wxgui need
>> some service not running in a bare linux window manager, which is
>> running in a typical full desktop environment?
>> Regards,
>> Tomas Brunclik
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-user
