[GRASS-user] (Linux) WXGUI not launching command windows in Fluxbox
Huidae Cho
grass4u at gmail.com
Tue Apr 11 00:38:20 PDT 2017
Tomas,
I'm running GRASS trunk on pure Fluxbox 1.3.7 x86-64. I cannot replicate
this problem by starting "grass -gui". Can you tell me how you started your
grass session? Looks like your fluxbox settings? wxGUI doesn't require any
special services only running in a full desktop environment.
Regards,
Huidae
On Mon, Apr 10, 2017 at 5:18 AM, Tomáš Brunclík <brunclik at atlas.cz> wrote:
> Update2: Everything works in Blackbox WM, so it is either issue of
> Fluxbox, or my configuration of it. Still, it would be interesting if some
> Fluxbox enthusiast would test it. Probably not worth to bother for others..
> Tomas B.
> Tomáš Brunclík napsal(a):
> Update: I just tried with Fluxbox running inside MATE instead of its
>> default Marco window manager, with the same results as running bare
>> Fluxbox. Maybe it is Fluxbox specific? (Fluxbox 1.3.5)
>> Tomas B
>>> Hello all,
>>> I just encountered strange wxgui behaviour (Linux 64bit, GRASS 7.2.1svn
>>> r70326 binary snapshot):
>>> When I run it from MATE desktop environment, everything works normally.
>>> When I run it from Fluxbox, wxgui starts, I can select location and
>>> mapset, the main program starts normally. But then, selecting (almost) any
>>> interactive command from menu, i.e. v.info or g.region, nothing
>>> happens. Also, when I try to run the same command without parameters from
>>> the console within the layer manager window, nothing happens, nothing shows
>>> in the console log file if I activate it. When I try to run the same
>>> command from the terminal emulator window running in the GRASS session, it
>>> normally launches the v.info window. Very few actions do open a window
>>> from menu, so far I discovered g.gui.gcp, "Add more raster or vector maps
>>> (Ctrl-Shift-L)" and "Run script" in File menu and panel icons working
>>> (translation of menu items from Czech).
>>> Selecting a non-interactive menu item, or putting it in the console,
>>> like g.region -p ( menu "Settings/Region/Show whole region (g.region -p)"
>>> ), the command works and shows its output in the output pane of the console
>>> tab.
>>> Can anyone reproduce this? Is it normal, i.e. does the wxgui need some
>>> service not running in a bare linux window manager, which is running in a
>>> typical full desktop environment?
>>> Regards,
>>> Tomas Brunclik
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170411/37cb9e25/attachment.html>
