[GRASS-user] g.list ... -1073741701
Edmund Swylan
Edmund.Swylan at ponymail.com
Mon Aug 14 05:56:40 PDT 2017
ES> I seem to have just installed GRASS 7.2.1 under Windows XP along with
ES> the spearfish60_grass7. An attempt to start a session with
ES> (spearfish...,user1) gets return code -1073741701;
ES> the g.list test does not get any complaint about sqlite3.dll
ES> (the message mentions 0xc000007b) but I have tried hiding competing
ES> sqlite3.dlls anyway - to no avail.
MN> Searching in the net I found the hint that there may be a mixup of
MN> 64bit and 32bit DLLs:
MN> Similar issues:
MN> https://stackoverflow.com/questions/11648621/c-sdl-native-has-exited-with-code-1073741701-0xc000007b
MN> https://stackoverflow.com/questions/32990900/opencv-and-qt-exit-code-1073741701
MN> Could you please check if you got any 64bit DLL in the way? I suppose
MN> that your XP installation is a 32bit system.
Dear Markus,
Thank you very much for your response.
Yes, the XP installation is 32 bit.
I have made sure that the sqlite3.dll from the ...\extrabin and no other
gets used by renaming this squlite3.dll and getting it reported as missing.
I have tried three sqlite3.dlls from my collection and got the -1073741701
in all cases. At least one of the three works as expected in other contexts.
I have observed that the sqlite3.dll in WinGRASS-7.2.1-1-Setup-x86.exe
is the biggest of the lot though not the newest.
I have also tried - for the first time - a GRASS 7.2.0 that came with
QGIS 2.14 (and two sqlite.dlls: one QGIS 2.14's and another for saga);
-1073741701.
Perhaps another .dll is to blame? Which .dlls might be relevant and
- probably - not used by SQLite in non-spatial contexts?
Edmund
