[GRASS-user] Creating STRDS from scratch
Veronica Andreo veroandreo at gmail.com
Tue Feb 21 14:53:50 PST 2017
Dear Rich,
If your maps represent intervals, then yes, it is correct to use -i. What
-i does is create intervals of the given increment (1 day) starting from
the start date that you pass (2013-11-15).
You can check the results of using -i and not using it, with t.info and
t.rast.list. if you do not use the flag what you get is time instances or
time points (maps with only start time). But again, it all depends on the
data you have.
HTH,
Vero
El 21 feb. 2017 11:05 p. m., "Rich Shepard" <rshepard at appl-ecosys.com>
escribió:
  Having read the temporal data processing/maps registration wiki page I
want to check that I'm using the correct t.register syntax for my data.
  A series of maps exists with names of the format 'rainfall_YYYYMMDD'.
While these define the start_time and end_time each file represents one
day's value (as an hourly rate) so I believe that I can use a start_time and
duration description:
t.register -i input=rainfall maps='g.list type=raster pattern=rainfall_*' \
separator=comma start='2013-11-15' increment='1 days'
  Is this correct? Or, should I use:
t.register input=precipitacion maps='g.list type=raster pattern=rainfall_* \
separator=comma start="2013-11-15" increment="1 days"
without the '-i' option?
Rich
grass-user mailing list
grass-user at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170221/aa37c154/attachment.html>
