[GRASS-user] Importing NAIP from WMS?
Jeff McKenna jmckenna at gatewaygeomatics.com
Tue Jul 4 07:12:50 PDT 2017
I guess I cheated here and used d.wms (gui) instead of an r.in.wms
command.  Anyway, I tried :)
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 2017-07-04 10:54 AM, Jeff McKenna wrote:
> Followup:  I was able to get the NAIP California WMS service working
> with GRASS, here were my steps:
> - installed winGRASS 7.3-dev from
> https://wingrass.fsv.cvut.cz/grass73/x86_64/
> - followed steps in the manual to execute a GetCapabilities request:
>     - in "Console" tab, executed this command:
>           r.in.wms -c
> url=https://gis.apfo.usda.gov/arcgis/services/NAIP/California_2016_60cm/ImageServer/WMSServer?
> - then used the "Add web service layer" menu item in GRASS:
>     - File/Map display/Add web service layer
>     - in the "Server" box enter:
> and click "Connect"
>     - wait for GetCapabilities to be parsed
>     - you should see a new dialogue window below open, with a layer listed
>     - click on the layer, select "EPSG:4326" as your source projection
> (assuming you have setup a GRASS location for that projection), select
> "png", and press "Add Layer"
> - the California image should appear in your map display
> - note that I used another WMS service to load the world continents
> (such as http://demo.mapserver.org/cgi-bin/wms?) and then zoomed into
> California extents that way, so I could see that layer
> - should look like: https://pasteboard.co/GznOi0u.png
> Hope that helps!  Have a good week (and happy late Canada Day!!)
> -jeff
