[GRASS-user] Change value of cells in raster map
Helmut Kudrnovsky
hellik at web.de
Fri Jun 9 06:23:21 PDT 2017
Rich Shepard wrote
> On Thu, 8 Jun 2017, Helmut Kudrnovsky wrote:
>> raster A:
>> raster B: raster eg with values 1 and 2
>> in R.mapcalc :
>> if(B==1, A, A/B)
>> which means in the resulting map: if the cell value in B is equal to 1,
>> then
>> take the raster cell value of raster A, otherwise divide the raster cell
>> value of A by the raster cell value of B.
> Helmut,
> I understand this produces a new map from two maps with different
> values.
> My two raster maps have the same value (2) because they come from dividing
> a
> single vector map whose area has a single value.
> I'm trying various v.db.* modules to change values in the two vector
> maps,
> then I can recreate the vector maps from these and each will have the
> desired value. So far no success, but I'll keep trying.
> Thanks,
> Rich
> grass-user mailing list
> grass-user at .osgeo
> https://lists.osgeo.org/mailman/listinfo/grass-user
https://grass.osgeo.org/grass73/manuals/v.db.update.html
-Add e.g. a integer column to the vector
- Insert 1 and 2 for the polygons in this column by v.db.update
- V.to.rast by attributes
- R.mapcalc
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Change-value-of-cells-in-raster-map-tp5323575p5323656.html
Sent from the Grass - Users mailing list archive at Nabble.com.
