[GRASS-user] Hardware requirements to run GRASS
Rich Shepard
rshepard at appl-ecosys.com
Tue Jun 13 06:34:22 PDT 2017
On Tue, 13 Jun 2017, Luís Moreira de Sousa wrote:
> However, there are some basic clues I could give. For instance, can GRASS
> run on a 16-bit system? Or 8-bit? What is the minimum RAM required to
> launch the GRASS console?
Luís,
Then let me suggest you look at the Dell website and use the specs for a
mid-level desktop system. A minimum of 32-bit CPU would be one end of the
spectrum, but to be realistic for a system that would be suitable for
several more years, I'd go with a 64-bit system, at least 4G RAM, and 500G
of hard drive (preferably SSD). Of courze, the operating system for the
hardware is also important and one should remember that GRASS was developed
to run on hardware running various flavors of UNIX so linux or freeBSD would
maximize use of the hardware. (Disclosure: the latter is my personal opinion
based on running my business on only linux and F/OSS for the past 20 years.)
HTH,
Rich
