[GRASS-user] Unable to open the Corine land cover map using GrassGIS 7
Stefan Blumentrath
Stefan.Blumentrath at nina.no
Mon Oct 9 07:37:20 PDT 2017
Hi Hakim,
Try r.import (https://grass.osgeo.org/grass72/manuals/r.import.html).
ETRS LAEA (EPSG:3035) is of course “supported”.
Cheers
Stefan
From: grass-user [mailto:grass-user-bounces at lists.osgeo.org] On Behalf Of Hakim Benoudjit
Sent: mandag 9. oktober 2017 16.02
To: grass-user at lists.osgeo.org
Subject: [GRASS-user] Unable to open the Corine land cover map using GrassGIS 7
I'm unable to open the Coring Land cover map (100m accuracy version) for Europe using GrassGIS, which can be downloaded from http://land.copernicus.eu/pan-european/corine-land-cover/clc-2012.
Apparentely the coordinate system of this land cover map isn't supported (The projection is ETRS89 (EPSG:3035)), while the projection of the location I'm trying to import the raster to is WGS84 (EPSG:4326). Here is the error shown in GrassGIS: ERROR: Coordinate reference system not available for input <C:\Data\Corine Land Cover\g100_clc12_V18_5a\g100_clc12_V18_5.tif>
Is there a workaround in GrassGIS to open this image?
Otherwise which tool should I use to reproject it?
Thanks.
Hakim.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20171009/24e72ff3/attachment-0001.html>
