[GRASS-user] Unable to open the Corine land cover map using GrassGIS 7
Helmut Kudrnovsky hellik at web.de
Tue Oct 24 12:38:39 PDT 2017
Markus Metz-3 wrote
> On Tue, Oct 24, 2017 at 4:53 PM, Veronica Andreo <
> veroandreo@
> wrote:
>> Hi,
>> I'm facing this same problem...
>> I have my EPSG:3035 location and when using r.import with -o flag to
> override projection check and import corine land cover, I get:
>> GRASS 7.3.svn (eu_laea):~> r.import -o input=g250_clc06_V18_5.tif
> output=clc06_V18_5_250m resample=nearest extent=region resolution=value
> resolution_value=250  title="Corine Land Cover 2006 - 250m - V18.5"
>> ERROR: Unable to convert input map projection to GRASS format; cannot
> create new location.
>> ERROR: Unable to read GDAL dataset
> <g250_clc06_V18_5.tif>
>> while -o flag is supposed to override the check and import. This used to
> work before. Am I missunderstanding something here?
> r.import needs to be adjusted to import the raster map directly into the
> current location if the -o flag is given.
> The underlying reason is that g250_clc06_V18_5.tif has projection
> information that is invalid. This invalid projection information is
> printed
> out as WKT before the error messages. You can also check with gdalinfo
just reported the invalid SRS to the data provider.
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
