[GRASS-user] Unable to open the Corine land cover map using GrassGIS 7
Markus Metz
markus.metz.giswork at gmail.com
Wed Oct 25 00:24:48 PDT 2017
On Tue, Oct 24, 2017 at 5:15 PM, Helmut Kudrnovsky <hellik at web.de> wrote:
> Veronica Andreo wrote
> > Hi,
> > I'm facing this same problem...
> > I have my EPSG:3035 location and when using r.import with -o flag to
> > override projection check and import corine land cover, I get:
> > GRASS 7.3.svn (eu_laea):~> r.import -o input=g250_clc06_V18_5.tif
> > output=clc06_V18_5_250m resample=nearest extent=region resolution=value
> > resolution_value=250 title="Corine Land Cover 2006 - 250m - V18.5"
> > ERROR: Unable to convert input map projection to GRASS format; cannot
> > create new location.
> > ERROR: Unable to read GDAL dataset
> > <g250_clc06_V18_5.tif>
> > while -o flag is supposed to override the check and import. This used to
> > work before. Am I missunderstanding something here?
> confirmed
> r.import input=D:\dl\ne\g250_clc12_V18_5a\g250_clc12_V18_5.tif
> output=g250_clc12_V18_5 -o
create
> new location.
> <D:\dl\ne\g250_clc12_V18_5a\g250_clc12_V18_5.tif>
> where does 'cannot create new location' comes from?
r.import / v.import tried to create a temporary location even if it is not
needed and direct import works. Fixed in trunk r71590.
Markus M
> best regards
> Helmut
> Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20171025/fe53810b/attachment.html>
