[GRASS-user] R: R: Grass 7.4.0 install error
Helmut Kudrnovsky
hellik at web.de
Fri Feb 9 04:01:30 PST 2018
[please keep it on the ML]
>Gesendet: Freitag, 09. Februar 2018 um 12:32 Uhr
>Von: "Aldo CLERICI"
>Sorry, here the translation:
>g.list.exe - Impossible to find the entry point
>sqlite3_column-origin_name of the procedure in the dynamic link library C:\OSGE04~1\bin\gdal202.dll.
it looks like there is another sqlite3 in your %PATH%.
see e.g.
http://osgeo-org.1560.x6.nabble.com/ERROR-quot-The-procedure-entry-point-sqlite3-open-v2-could-not-be-located-in-the-dynamic-link-librarn-td4981789.html
which interferes with the OSGeo4W sqlite3.
as already yesterday mentioned on the ML:
could you type in a windows console:
where "$path:sqlite3*"
or search in C:\Windows in the explorer for sqlite3*
and report the results here on the ML
kind regards
Helmut
-----Messaggio originale-----
Da: grass-user [mailto:grass-user-bounces at lists.osgeo.org] Per conto di Helmut Kudrnovsky
Inviato: giovedì 8 febbraio 2018 18:29
A: grass-user at lists.osgeo.org
Oggetto: Re: [GRASS-user] R: Grass 7.4.0 install error
Aldo Clerici wrote
> I tried to install 7.4.0 via OSGeo4W on my Windows 10 PC but without
> success (see error in att.1-2) I installed 7.4.0, 7.2.2 via
> Stand-alone installer and 7.4.0 via OSGeoW4 on an old PC with Windows
> 7 and all work fine.
> Surely something strange in my Windows 10 OS, but it's strange I was
> able to install 7.2.0 and 7.0.x not long ago.
> I'll try to discover the problem with some Windows expert at my
> Department.
> Many thanks to everybody.
> Aldo Clerici
could you translate the error messages?! it's italian....
AFAIU it's not a windows 10 problem, but a missing dependency problem.
could you try following steps in OSGeo4W:
- delete your OSGeo4W installation
- start with a new fresh OSGeo4W installation by first only a basic installation, i.e. GDAL, proj4,
- open the OSGeo4W shell and type: gdalinfo --version to see if GDAL crashes
- then install GRASS7.4 in OSGeo4W
- try to open GRASS7.4 and see if it crashes
- then install QGIS and see if it crashes
and report back the results of the several steps.
the qgis-common-error seems not to be a GRASS error.
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
grass-user mailing list
https://lists.osgeo.org/mailman/listinfo/grass-user[https://lists.osgeo.org/mailman/listinfo/grass-user]
