[GRASS-user] Cannot re-install Grass 7.2
Mira Kattwinkel kattwinkel-mira at uni-landau.de
Fri Feb 16 06:38:47 PST 2018
I tried this but still get the same error.
On 16/02/18 15:20, Moritz Lennert wrote:
> On 16/02/18 15:11, Moritz Lennert wrote:
>> On 16/02/18 15:01, Mira Kattwinkel wrote:
>>> Hi,
>>> qgis-plugin-grass depends on Grass 7.2, hence when I try to install
>>> it I
>>> get the following message:
>>> mira at mira-mint ~ $ sudo apt-get install qgis-plugin-grass
>>> Reading package lists... Done
>>> Building dependency tree
>>> Reading state information... Done
>>> Some packages could not be installed. This may mean that you have
>>> requested an impossible situation or if you are using the unstable
>>> distribution that some required packages have not yet been created
>>> or been moved out of Incoming.
>>> The following information may help to resolve the situation:
>>> The following packages have unmet dependencies:
>>>     qgis-plugin-grass : Depends: grass722 but it is not installable
>>> E: Unable to correct problems, you have held broken packages.
> But I'm a bit surprised by this. Looking at the ubuntugis-unstable
> page, I don't see any dependency to qgis-plugin-grass to grass 7.2. On
> the contrary, it depends on grass-core (>= 7.4.0).
> Maybe there was just a missing "apt-get update" before trying to
> install the plugin ?
> Try again with ubuntugis-unstable, apt-get update, apt-get upgrade and
> see what happens.
> Moritz
Dr. Mira Kattwinkel
Quantitative Landscape Ecology
Institute for Environmental Sciences
University of Koblenz-Landau
Fortstraße 7
76829 Landau
Germany
Phone: + 49 6341 280-31553
Office: Building I, Room 2.02
