[GRASS-user] Fwd: ASC files - Contours lines on elevation map on GRASS 7.4/Ubuntu 16.04
Kevin Labre kxmlab at gmail.com
Wed Feb 21 02:31:15 PST 2018
Dear list,
I'm quite new to GRASS and Ubuntu, it might be an easy question.
I'm trying to display contour lines on a map of the piece of land I'm
buying.
The data used is 4 .asc files with respective .prj files created under
ARCGis on Windows, projection RGFG95 UTM 22N. They're imported into Grass
using the r.import command.
I can load them and managed to display contour lines using r.contour on one
or the other, but not the four tiles altogether:
Are there any steps I'm missing?
Thanks for your time!
Kevin
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180221/c3d53342/attachment-0001.html>
Name: Screenshot from 2018-02-20 20-24-10.jpg
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180221/c3d53342/attachment-0001.jpg>
