[GRASS-user] Fwd: ASC files - Contours lines on elevation map on GRASS 7.4/Ubuntu 16.04
Daniel Victoria daniel.victoria at gmail.com
Wed Feb 21 03:54:36 PST 2018
It's been a while since I used ARC so I might be a bit confused here. The
ASC file you have is a GRIDASCII correct? That is why you are importing it
using r.import?
Anyway, during r.import you can crop the image to the current region
settings (using the extent parameter). Check to see if that is not the
case. Thus, in your r.import command use extent=input or just don't use
that option at all, since that is the default.
Another thing that might help is if you patch the MNT rasters, you can set
a nicer colortable. Take a look at r.patch
Cheers
Daniel
On Wed, Feb 21, 2018 at 7:31 AM Kevin Labre <kxmlab at gmail.com> wrote:
> Dear list,
> I'm quite new to GRASS and Ubuntu, it might be an easy question.
> I'm trying to display contour lines on a map of the piece of land I'm
> buying.
> The data used is 4 .asc files with respective .prj files created under
> ARCGis on Windows, projection RGFG95 UTM 22N. They're imported into Grass
> using the r.import command.
> I can load them and managed to display contour lines using r.contour on
> one or the other, but not the four tiles altogether:
> [image: Screenshot from 2018-02-20 20-24-10.jpg]
> Are there any steps I'm missing?
> Thanks for your time!
> Kevin
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180221/0618d232/attachment-0001.html>
Name: Screenshot from 2018-02-20 20-24-10.jpg
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180221/0618d232/attachment-0001.jpg>
