[GRASS-user] Spatial data exchange formats
    Daniel Victoria
    daniel.victoria at gmail.com
    Mon Jun 18 06:20:16 PDT 2018
Hi Rich,
Actually, your ADF file is part of a vector format from ESRI named
Coverage, that includes some files in a folder with the name of your data
and some other data in a folder called INFO. Here is some more info on the
Coverage format [1]
GDAL OGR can handle both shape and coverage formats so you could import any
of the two. I believe it does not matter which one you choose. Just fire up
GRASS and import your vector file.
To import the Coverage, I believe in GRASS you have to select the ADF file
inside the coverage directory. To import the shapefile, just select the
file with the shp extension
Cheers
Daniel
[1] - https://support.esri.com/en/technical-article/000007209
On Fri, Jun 8, 2018 at 3:15 PM Rich Shepard <rshepard at appl-ecosys.com>
wrote:
> On Wed, 30 May 2018, Helmut Kudrnovsky wrote:
> > So you have to look by ogrinfo/gdalinfo --formats; you can get further
> > information on the GDAL Website.
>    I have LiDAR files in two ESRI formats and don't know which would be the
> better one to use: .shp and .adf.
>    My research taught me that .adf is Amiga Data File, and I thought that
> Amiga died several decades ago. Seems that ESRI is using that format for
> some reason and it does not appear to be supported by gdal.
>    The directories with the adf files also contain .dat, .nit, and .dir
> files and come in three versions: bare earth, highest hits, and intensity.
>    My use of these DEMs is for hydrological modeling, including storm
> runoff
> with times of concentration for specified 24-hour storm hydrographs. So, I
> want to become informed about my choices. Recommended readings also
> appreciated.
> Regards,
> Rich
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180618/0280a926/attachment.html>
