[GRASS-user] Spatial data exchange formats
Daniel Victoria
daniel.victoria at gmail.com
Thu Jun 21 10:44:22 PDT 2018
OK.
I tried to download the data you placed on file dropper (other email
tread). But both links you sent gave me corrupt files.
If you can manage to place the files in some shared folder or point to the
original data source, I can take a look.
Have you tried opening in some other software, like QGis?
Cheers
Daniel
On Thu, Jun 21, 2018 at 2:24 PM Rich Shepard <rshepard at appl-ecosys.com>
wrote:
> On Thu, 21 Jun 2018, Daniel Victoria wrote:
> > ESRI ArcINFO used two formats that spreded files into a directory with
> the
> > layer name and another directory called INFO. In the directory with the
> > layer name, the files had the .ADF extension you mentioned in the first
> > email. But their content is different.
> Daniel,
> In the late 1980s I used Arc/INFO on a Prime and pc-arc/info on a pc.
> Info
> was the attribute database.
> > From the list you sent, you have a file named hdr.adf, which is a
> giveaway
> > that we are dealing with an ESRI GRID (raster format). The presence of a
> > .OVR file also indicates that it's a grid, OVR being the raster pyramid
> > overviews.
> Thought so.
> > So, if you have a Raster product, it means that the person providing the
> > data took care of the processing to generate both the bare earth model
> and
> > the highest hit.
> > Anyway, you can use r.in.gdal to import those GRIDS into GRASS. Just
> point
> > to the hdr.adf file and all should be OK.
> My problems are that pointing r.in.gdal to the hdr.adf files display
> only
> the strange wedge/rectangle I attached to messages earlier in this thread.
> They should be retangles for a full 1 degree x 1 degree topographic quad
> map
> with colors varying by elevation.
> My need is to learn why I'm not getting clean imports of either
> bare_earth
> or highest_hits for any of the three years of data. This is why this thread
> has continued so long. The only option to r.in.gdal I've used is '-o' to
> use the source's projection for the map.
> Thanks,
> Rich
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180621/a11a185a/attachment.html>
