[GRASS-user] r.fuzzy.logic problem
bonatopaola at libero.it bonatopaola at libero.it
Thu May 17 07:43:02 PDT 2018
Hi all,
I'm new with GRASS GIS and I'm interesting to learn the use of r.fuzzy.* tools. I read Jasiewicz paper (A new Grass GIS fuzzy inference system for massive data analys) and I run r.fuzzy.system tool without error. Now I'm trying to understand the process step by step using r.fuzzy.set and r.fuzzy.logic. I produced membership raster with r.fuzzy.set but when I use its outputs to run  r.fuzzy.logic I have the follow error: ERROR: <accum_abs_high_memb at PERMANENT> is not of type CELL.
The tool requires two input raster data and both are FCELL. I have no idea where can be the error, both input data are from r.fuzzy.set.
I'm running Grass GIS 7.2.1 in Window 10 and I'm using spearfish60_grass7 maps.
Thanks in advance.
Paola
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180517/02fe516b/attachment.html>
