[GRASS-user] r.fuzzy.logic problem
Moritz Lennert
mlennert at club.worldonline.be
Thu May 17 08:06:57 PDT 2018
On 17/05/18 17:06, Moritz Lennert wrote:
> On 17/05/18 16:43, bonatopaola at libero.it wrote:
>> Hi all,
>> I'm new with GRASS GIS and I'm interesting to learn the use of r.fuzzy.*
>> tools. I read Jasiewicz paper (A new Grass GIS fuzzy inference system
>> for massive data analys) and I run r.fuzzy.system tool without error.
>> Now I'm trying to understand the process step by step using r.fuzzy.set
>> and r.fuzzy.logic. I produced membership raster with r.fuzzy.set but
>> when I use its outputs to runĀ r.fuzzy.logic I have the follow error:
>> ERROR: <accum_abs_high_memb at PERMANENT> is not of type CELL.
>> The tool requires two input raster data and both are FCELL. I have no
>> idea where can be the error, both input data are from r.fuzzy.set.
>> I'm running Grass GIS 7.2.1 in Window 10 and I'm using
>> spearfish60_grass7 maps.
> AFAICT, the message about CELL was an typo (should be FCELL), and one of
> the FCELL types was ignored and the module fataled out in any case.
> Shows that you are probably the first one to use these modules in a long
> time...
> I've tried to correct according to my understanding after a rapid
> reading of the code. Could you reinstall the module with g.extension and
> tell us if the error has been corrected ?
Sorry, just saw that you are on Windows: you will have to wait for the
module to be recompiled to get the changes. The latest tomorrow...
Moritz
