[GRASS-user] r.fuzzy.logic problem
bonatopaola at libero.it bonatopaola at libero.it
Thu May 17 13:04:30 PDT 2018
>     Il 17 maggio 2018 alle 17.06 Moritz Lennert <mlennert at club.worldonline.be> ha scritto:
>     On 17/05/18 17:06, Moritz Lennert wrote:
> >         On 17/05/18 16:43, bonatopaola at libero.it wrote:
> > >             Hi all,
> > >             I'm new with GRASS GIS and I'm interesting to learn the use of r.fuzzy.*
> > >             tools. I read Jasiewicz paper (A new Grass GIS fuzzy inference system
> > >             for massive data analys) and I run r.fuzzy.system tool without error.
> > >             Now I'm trying to understand the process step by step using r.fuzzy.set
> > >             and r.fuzzy.logic. I produced membership raster with r.fuzzy.set but
> > >             when I use its outputs to run r.fuzzy.logic I have the follow error:
> > >             ERROR: <accum_abs_high_memb at PERMANENT> is not of type CELL.
> > >             The tool requires two input raster data and both are FCELL. I have no
> > >             idea where can be the error, both input data are from r.fuzzy.set.
> > >             I'm running Grass GIS 7.2.1 in Window 10 and I'm using
> > >             spearfish60_grass7 maps.
> >         AFAICT, the message about CELL was an typo (should be FCELL), and one of
> >         the FCELL types was ignored and the module fataled out in any case.
> >         Shows that you are probably the first one to use these modules in a long
> >         time...
> >         I've tried to correct according to my understanding after a rapid
> >         reading of the code. Could you reinstall the module with g.extension and
> >         tell us if the error has been corrected ?
>     Sorry, just saw that you are on Windows: you will have to wait for the
>     module to be recompiled to get the changes. The latest tomorrow...
>     Moritz
Thank you Moritz,
I installed OsgeoLive virtual box with GRASS to run fuzzy tools also with Linux, so I'll run r.fuzzy.logic there and I'll tell you if it works.
Paola
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180517/9b6c5f8b/attachment.html>
