[GRASS-user] r.fuzzy.logic problem
bonatopaola at libero.it bonatopaola at libero.it
Fri May 18 03:51:10 PDT 2018
> Il 17 maggio 2018 alle 22.04 bonatopaola at libero.it ha scritto:
> >         Il 17 maggio 2018 alle 17.06 Moritz Lennert <mlennert at club.worldonline.be> ha scritto:
> >         On 17/05/18 17:06, Moritz Lennert wrote:
> > >             On 17/05/18 16:43, bonatopaola at libero.it wrote:
> > > >                 Hi all,
> > > >                 I'm new with GRASS GIS and I'm interesting to learn the use of r.fuzzy.*
> > > >                 tools. I read Jasiewicz paper (A new Grass GIS fuzzy inference system
> > > >                 for massive data analys) and I run r.fuzzy.system tool without error.
> > > >                 Now I'm trying to understand the process step by step using r.fuzzy.set
> > > >                 and r.fuzzy.logic. I produced membership raster with r.fuzzy.set but
> > > >                 when I use its outputs to run r.fuzzy.logic I have the follow error:
> > > >                 ERROR: <accum_abs_high_memb at PERMANENT> is not of type CELL.
> > > >                 The tool requires two input raster data and both are FCELL. I have no
> > > >                 idea where can be the error, both input data are from r.fuzzy.set.
> > > >                 I'm running Grass GIS 7.2.1 in Window 10 and I'm using
> > > >                 spearfish60_grass7 maps.
> > >             AFAICT, the message about CELL was an typo (should be FCELL), and one of
> > >             the FCELL types was ignored and the module fataled out in any case.
> > >             Shows that you are probably the first one to use these modules in a long
> > >             time...
> > >             I've tried to correct according to my understanding after a rapid
> > >             reading of the code. Could you reinstall the module with g.extension and
> > >             tell us if the error has been corrected ?
> >         Sorry, just saw that you are on Windows: you will have to wait for the
> >         module to be recompiled to get the changes. The latest tomorrow...
> >         Moritz
>     Thank you Moritz,
>     I installed OsgeoLive virtual box with GRASS to run fuzzy tools also with Linux, so I'll run r.fuzzy.logic there and I'll tell you if it works.
>     Paola
Hi Moritz,
r.fuzzy.logic works!
Thank you,
Paola
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180518/412bc5c3/attachment.html>
