[GRASS-user] r3.out.vtk for paraview
Francois Chartier
fra.chartier at gmail.com
Wed Nov 21 18:58:00 PST 2018
Problem solved. the solution is to define the folder location where the
file should be saved.... typically, we just have to define the file name
(Wed Nov 21 21:55:24 2018)
r3.out.vtk -s input=nov817tension100 at Toronto output=C:\Users\Francois
Chartier\Documents\GeoModel\vtktrial top=GTA_DEM_Raster at PERMANENT
bottom=Rock at Toronto
The 2D and 3D region settings are different. Using the 2D window settings
to adjust the 2D part of the 3D region.
(Wed Nov 21 21:56:13 2018) Command finished (49 sec)
Le mer. 21 nov. 2018 à 21:39, Francois Chartier <fra.chartier at gmail.com> a
écrit :
> I have tried without the advanced options and the error message is that
> Permission Denied.
> (Wed Nov 21 21:37:26 2018)
> r3.out.vtk input=nov817tension100 at Toronto output=vtk
> top=GTA_DEM_Raster at PERMANENT bottom=Rock at Toronto
> vtk: Permission denied
> Converts 3D raster maps into the VTK-ASCII format.
> Usage:
> r3.out.vtk [-psmocl] [input=name[,name,...]] [output=name]
> [null=value] [top=string] [bottom=string]
> [rgbmaps=name[,name,...]]
> [vectormaps=name[,name,...]] [zscale=value]
> [precision=value]
> [--overwrite] [--help] [--verbose] [--quiet] [--ui]
> Flags:
> -p Create VTK pointdata instead of VTK celldata
> (celldata is default)
> -s Create 3D elevation output with a top and a bottom
> surface, both raster maps are required.
> -m Use 3D raster mask (if exists) with input maps
> -o Scale factor affects the origin
> -c Correct the coordinates to match the VTK-OpenGL
> precision
> -l Do not convert the top-bottom resolution in case of
> lat long projection to meters
> Parameters:
> input 3D raster map(s) to be converted to VTK-ASCII
> data format
> output Name for VTK-ASCII output file
> On Wed, Nov 21, 2018, 15:19 Markus Neteler <neteler at osgeo.org wrote:
>> On Wed, Nov 21, 2018 at 1:45 PM Francois Chartier
>> <fra.chartier at gmail.com> wrote:
>> > I created 3 rgb maps using the same DEM file. should i be using 3
>> different Dem or raster files instead?
>> > Wouldnt it make more sense to be using RGB files developped based on
>> the 3d raster (even if that option doesnt exist).
>> Maybe there is a misunderstanding? The RGB parameter is for draping a
>> (color) image over the DEM.
>> See for example:
>> https://grasswiki.osgeo.org/wiki/GRASS_and_Paraview#RGB_visualization
>> (in the 3D case I am not sure what to drape in color over a volume but
>> it could be some extra parameter).
>> Markus
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20181121/c8b9c2ac/attachment.html>
