[GRASS-user] append data after a v.in.ascii import
Frank David
frank.david at geophom.fr
Fri Oct 26 10:17:43 PDT 2018
Thank you Markus,
Is a feature could be created without a row data ?, because the two
maps have been created with a v.in.ascii from a text file, so it means
that one object by row has been created. For both of my two maps.
Frank
Le 26/10/2018 à 18:44, Markus Metz a écrit :
> On Fri, Oct 26, 2018 at 2:26 PM Frank David <frank.david at geophom.fr
> <mailto:frank.david at geophom.fr>> wrote:
> > I reply to myself,
> > I mistook, if I append, I see a cat shift too. The fisrt cat of the
> > second map is shift by one. It's strange no ?
> Suppose there is a feature with cat 1 in map A and a feature also with
> cat 1 in map B, but corresponding attribute values for cat 1 are
> different between map A and map B. In order to avoid such conflicts,
> v.patch shifts category values and updates the resultant attribute
> table accordingly, such that attributes for each feature are preserved.
> Markus M
> > Frank
> > Le 26/10/2018 à 14:17, Frank David a écrit :
> > > Hi Stephan,
> > > If I add two vector in a new one with :
> > > v.patch -c input=map1,map2 out=map3
> > > I notice the map3 first cat start at 2 instead of 1, so all cat are
> > > shifted by one. Do you have an idea of the reason ?
> > > If I append my map1 with map2 :
> > > v.patch -c -a input=map2 output=map1 --overwrite it works well
> > > Thank you
> > > Frank
> > > Le 26/10/2018 à 12:01, Stefan Blumentrath a écrit :
> > >> Hi,
> > >> Try:
> > >> v.patch -a
> > >> https://grass.osgeo.org/grass76/manuals/v.patch.html
> > >> (assuming attribute tables are equal).
> > >> Cheers
> > >> Stefan
> > >> -----Original Message-----
> > >> From: grass-user<grass-user-bounces at lists.osgeo.org
> <mailto:grass-user-bounces at lists.osgeo.org>> On Behalf Of Frank David
> > >> Sent: fredag 26. oktober 2018 11:39
> > >> To:grass-user at lists.osgeo.org
> <mailto:To%3Agrass-user at lists.osgeo.org>
> > >> Subject: [GRASS-user] append data after a v.in.ascii import
> > >> Hello,
> > >> I wonder what is the best way to append a vector map and his
> attribute data created with v.in.ascii ?
> > >> Thanks
> > >> Frank
> > >> _______________________________________________
> > >> grass-user mailing list
> > >> grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
> > >> https://lists.osgeo.org/mailman/listinfo/grass-user
-------------- section suivante --------------
Une pièce jointe HTML a été nettoyée...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20181026/60d65149/attachment-0001.html>
