[GRASS-user] append data after a v.in.ascii import
Markus Metz markus.metz.giswork at gmail.com
Fri Oct 26 12:11:05 PDT 2018
On Fri, Oct 26, 2018 at 7:17 PM Frank David <frank.david at geophom.fr> wrote:
> Thank you Markus,
> Is a feature could be created without a row data ?,  because the two maps
have been created with a v.in.ascii from a text file, so it means that one
object by row has been created. For both of my two maps.
If you want to preserve attribute values, use v.patch -e, otherwise don't
use the -e flag, but then you might get duplicate category values.
v.patch -c should not work because -c is not a recognised flag. Which GRASS
version did you use with v.patch -c?
Markus M
> Frank
> Le 26/10/2018 à 18:44, Markus Metz a écrit :
> On Fri, Oct 26, 2018 at 2:26 PM Frank David <frank.david at geophom.fr>
wrote:
> > I reply to myself,
> > I mistook, if I append, I see a cat shift too. The fisrt cat of the
> > second map is shift by one. It's strange no ?
> Suppose there is a feature with cat 1 in map A and a feature also with
cat 1 in map B, but corresponding attribute values for cat 1 are different
between map A and map B. In order to avoid such conflicts, v.patch shifts
category values and updates the resultant attribute table accordingly, such
that attributes for each feature are preserved.
> Markus M
> > Frank
> > Le 26/10/2018 à 14:17, Frank David a écrit :
> > > Hi Stephan,
> > > If I add two vector in a new one with :
> > > v.patch -c input=map1,map2 out=map3
> > > I notice the map3 first cat start at 2 instead of 1, so all cat are
> > > shifted by one. Do you have an idea of the reason ?
> > > If I append my map1 with map2 :
> > > v.patch -c -a input=map2 output=map1 --overwrite it works well
> > > Thank you
> > > Frank
> > > Le 26/10/2018 à 12:01, Stefan Blumentrath a écrit :
> > >> Hi,
> > >> Try:
> > >> v.patch -a
> > >> https://grass.osgeo.org/grass76/manuals/v.patch.html
> > >> (assuming attribute tables are equal).
> > >> Cheers
> > >> Stefan
> > >> -----Original Message-----
> > >> From: grass-user<grass-user-bounces at lists.osgeo.org>  On Behalf Of
Frank David
> > >> Sent: fredag 26. oktober 2018 11:39
> > >> To:grass-user at lists.osgeo.org
> > >> Subject: [GRASS-user] append data after a v.in.ascii import
> > >> Hello,
> > >> I wonder what is the best way to append a vector map and his
attribute data created with v.in.ascii  ?
> > >> Thanks
> > >> Frank
> > >> _______________________________________________
> > >> grass-user mailing list
> > >> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20181026/5fb2549c/attachment.html>
