[GRASS-user] create basins of similar area
Markus Metz markus.metz.giswork at gmail.com
Thu Apr 25 11:05:24 PDT 2019
On Thu, Apr 25, 2019 at 5:34 PM Moritz Lennert <mlennert at club.worldonline.be>
wrote:
> Am 25. April 2019 17:29:24 MESZ schrieb Martin Landa <
landa.martin at gmail.com>:
> >Hi,
> >čt 25. 4. 2019 v 17:19 odesílatel Francois Chartier
> ><fra.chartier at gmail.com> napsal:
> >> Use r.wathershed or r.basins.
> >well, I know these tools. I am just not sure how to control optimal
> >basin area (eg. 4-5km2). I just found `threshold` parameter.
> I don't really see how a homogeneous size could actually make sense. The
threshold allows you to define a minimum size, but depending on the actual
topography actual sizes of basins will always differ.
I agree. A solution could be manual editing: merge basins by adhering
hydrological rules (merge a downstream basin with an upstream basin granted
that other upstream basins do not become isolated). But hydrologically this
does not make sense, compare with stream order numbers.
Markus M
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190425/2695397c/attachment.html>
