[GRASS-user] create basins of similar area
Ken Mankoff
mankoff at gmail.com
Thu Apr 25 11:13:31 PDT 2019
Maybe make basins with threshold an order of magnitude smaller. Then merge
small areas to get your 4-5 km2 areas. Still not totally sure how this
makes sense hydrologically.
-k.
Please excuse brevity. Sent from tiny pocket computer with non-haptic
feedback keyboard.
On Thu, Apr 25, 2019, 16:05 Markus Metz <markus.metz.giswork at gmail.com>
wrote:
> On Thu, Apr 25, 2019 at 5:34 PM Moritz Lennert <
> mlennert at club.worldonline.be> wrote:
> > Am 25. April 2019 17:29:24 MESZ schrieb Martin Landa <
> landa.martin at gmail.com>:
> > >Hi,
> > >čt 25. 4. 2019 v 17:19 odesílatel Francois Chartier
> > ><fra.chartier at gmail.com> napsal:
> > >> Use r.wathershed or r.basins.
> > >well, I know these tools. I am just not sure how to control optimal
> > >basin area (eg. 4-5km2). I just found `threshold` parameter.
> > I don't really see how a homogeneous size could actually make sense. The
> threshold allows you to define a minimum size, but depending on the actual
> topography actual sizes of basins will always differ.
> I agree. A solution could be manual editing: merge basins by adhering
> hydrological rules (merge a downstream basin with an upstream basin granted
> that other upstream basins do not become isolated). But hydrologically this
> does not make sense, compare with stream order numbers.
> Markus M
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190425/d8d6a5dd/attachment-0001.html>
