[GRASS-user] ascii decode special character
Veronica Andreo
veroandreo at gmail.com
Fri Jan 4 04:08:08 PST 2019
Hi Frank,
Now I see what you mean, yes. Same happens for kilometers in Spanish.
I think this is worth a ticket in [0]. Please, provide a simple example and
instructions to reproduce the issue.
Cheers,
Vero
[0] https://trac.osgeo.org/grass/wiki
El jue., 3 ene. 2019 a las 20:21, Frank David (<frank.david at geophom.fr>)
escribió:
> Hi Vero,
> I mean that "kilometer" is not a string from my psmap, it's a part of
> scale object "scalebar" in the psmap file :
> scalebar s
> where 7.0 9.3
> length 10.0
> units kilometers
> height 0.04
> The translation in french (with accent), when the GUI is set in french, is
> made by Grass.
> All my special characters are well printed in my ps file, except the scale
> unit... ;-(
> Do you see what I mean ?
> Cheers,
> Frank
> Le 03/01/2019 à 13:40, Veronica Andreo a écrit :
> Hi Frank,
> Maybe I do not get what you mean, but changing the encoding for the psmap
> file and the running ps.map with the newly saved file helped me with
> special characters in Spanish such as accent and ñ. That's what we use
> ps.map for, no? Or what do you mean then?
> Cheers,
> Vero
> El jue., 3 ene. 2019 a las 12:43, Frank David (<frank.david at geophom.fr>)
> escribió:
>> Hi Vero,
>> Ok for updating.
>> Concerning the problem of special character in units (kilometer) scale
>> bar, we already had a post about that, and encoding in ISO-8859-1 does not
>> change anything about that (but solve the problem in text string from
>> user). I think the problem comes from grass code...
>> I met the same problem with v.label.
>> Cheers,
>> Frank
>> Le 03/01/2019 à 12:16, Veronica Andreo a écrit :
>> Hi Frank,
>> Good that you solved it :)
>> In any case, I would recommend you to update your grass version. There
>> have been quite some changes since August last year in trunk (Dev version).
>> Moreover, I think the ps.map issue could be solved by saving the psmap
>> instructions with a different encoding, no need to change language because
>> of that. Check the last paragraph under Notes in the manual [0].
>> HTH,
>> Vero
>> [0] https://grass.osgeo.org/grass77/manuals/ps.map.html
>> El jue., 3 ene. 2019 6:45, Frank David <frank.david at geophom.fr> escribió:
>>> Hi Markus,
>>> Hi Frank,
>>> Am Mi., 2. Jan. 2019, 16:56 hat Frank David <frank.david at geophom.fr>
>>> geschrieben:
>>>> Hello all,
>>>> I wish a very nice year to every GRASS user and also for GRASS
>>>> developments !
>>> Happy New Year!
>>> I met a decoding problem with "v.db.select map=my_vector
>>>> columns=my_name" when GRASS meet some special characters in the string
>>>> of my_name field. The string value is "Côte de la Bouchère".
>>>> See below the error message :
>>>> Traceback (most recent call last):
>>>> File
>>>> "/usr/local/grass-7.5.svn/gui/wxpython/gui_core/goutput.py",
>>>> line 472, in OnCmdOutput
>>>> self.cmdOutput.AddStyledMessage(message, type)
>>>> File
>>>> line 771, in AddStyledMessage
>>>> self.AddTextWrapped(message, wrap=None)
>>>> File
>>>> line 722, in AddTextWrapped
>>>> self.AddText(txt)
>>>> File "/usr/lib/python2.7/dist-
>>>> packages/wx-3.0-gtk2/wx/stc.py", line 2041, in AddText
>>>> return _stc.StyledTextCtrl_AddText(*args, **kwargs)
>>>> UnicodeDecodeError
>>>> 'ascii' codec can't decode byte 0xc3 in position 1: ordinal
>>>> not in range(128)
>>>> (Wed Jan 2 16:40:24 2019) Command finished (0 sec)
>>>> Is there anybody who know how I can solve this ? (with GRASS v7.5 on
>>>> debian9)
>>> Could you please send the precise version? It looks a bit dated.
>>> g.version -g
>>> version=7.5.svn
>>> date=2018
>>> revision=r
>>> build_date=2018-08-10
>>> build_platform=x86_64-pc-linux-gnu
>>> build_off_t_size=8
>>> But I was in en language. If I set in system (or french), it works!
>>> In fact, I'm using sometimes English GUI because the scale bar text in
>>> psmap is not well coded and is displayed kilomÄ"tre, in english kilometer.
>>> anyway, english GUI should handled special character isn't it ?
>>> Best regards,
>>> Frank
>>> Best
>>> Markus
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190104/ee6c21a3/attachment.html>
