[GRASS-user] How to use g.gui.animation with base map
Veronica Andreo
veroandreo at gmail.com
Mon Jan 14 05:10:33 PST 2019
Hello Andre,
I tried with an elevation map and a strds from the nc climate location [0].
I added the elevation map and then the strds and set opacity to 50% to the
latter and then hit play. It works just fine. I can see the elevation map
below. It is just a matter of ordering the layers AFAIU (see the arrows in
the GUI). I do not have a strds with gaps here to test though...
HTH,
Vero
[0]
http://courses.ncsu.edu/mea592/common/media/02/nc_climate_spm_2000_2012.zip
El sáb., 12 ene. 2019 a las 19:30, André Della Libera Zanchetta (<
adlzanchetta at gmail.com>) escribió:
> Hi community,
> I have a strds (space time raster data set) of precipitation and I
> would like to create an animation of it with above an static map (in
> the case, a DEM - digital elevation model) so that the cells with 0
> precipitation are set as transparent.
> In the manual, it is said that "each animation can consist of base map
> layer(s) and (multiple) series", so in my understanding I should be
> able to set my DEM as my base layer and my precipitation strds as the
> animated one in the composition. However, I was not able to do so.
> So the question is: how to animate an strds with a static base map?
> (any solution, be it in the GUI interface or via command, would help a
> lot!)
> Thanks,
> André.
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190114/81777523/attachment.html>
