[GRASS-user] 7.7.dev: No raster map displays
    Rich Shepard
    rshepard at appl-ecosys.com
    Wed Jul 24 10:43:28 PDT 2019
On Wed, 24 Jul 2019, Carlos Henrique Grohmann de Carvalho wrote:
> regarding the region setting, to adjust the resolution to 3m, use a "-a"
> flag ('g.region vect=analytical_area res=3 -pa')
Carlos,
The CRS is in international feet, not meters, but I'll use the -a option.
> also try to set the region, than re-run any previous steps (like re-import
> the raster), to be sure that any operation is being run with the proper
> region settings.
Will do. Good idea because the default region is probably much too small.
More later,
Rich
