[GRASS-user] 7.7.dev: No raster map displays
    Helmut Kudrnovsky
    hellik at web.de
    Wed Jul 24 11:32:36 PDT 2019
Rich Shepard wrote
> On Wed, 24 Jul 2019, Carlos Henrique Grohmann de Carvalho wrote:
>> regarding the region setting, to adjust the resolution to 3m, use a "-a"
>> flag ('g.region vect=analytical_area res=3 -pa')
> Carlos,
> The CRS is in international feet, not meters, but I'll use the -a option.
>> also try to set the region, than re-run any previous steps (like
>> re-import
>> the raster), to be sure that any operation is being run with the proper
>> region settings.
> Will do. Good idea because the default region is probably much too small.
> More later,
> Rich
> grass-user mailing list
> grass-user at .osgeo
> https://lists.osgeo.org/mailman/listinfo/grass-user
See
https://grass.osgeo.org/download/sample-data/
Ever tried with the NC sample data set?
It's easier to reproduce the steps you've done for the community.
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
