[GRASS-user] raster pixel value
Francois Chartier
fra.chartier at gmail.com
Sun Mar 10 07:56:40 PDT 2019
I am asking a question on the fundamentals not on a particular example on
how the value within a raster cell is determined when multiple vector data
points are located within a raster cell footprint.
I use RST mostly and sometimes IDW for vector data points.
Le dim. 10 mars 2019 à 10:05, Nikos Alexandris <nik at nikosalexandris.net> a
écrit :
> * Francois Chartier <fra.chartier at gmail.com> [2019-03-10 09:38:13 -0400]:
> >Hi
> >i was wondering how the value of a pixel is determined when multiple data
> >points are located within a pixel, for 2d and 3d pixel. I assume it is
> >based on the interpolation methodology of the raster. is this correct.
> >for large pixels where only data point is located within it, can the pixel
> >have a different value than that of the data point if through the
> >interpolation and due to surrounding points it generates a different
> value?
> >thks
> Dear Francois,
> your questions are a bit sketchy. What exactly are trying to do?
> How the value of a pixel is determined when multiple data points are
> located within a pixel?
> Which multiple data points are you referring to?
> Multiple raster data cells, which you get when you modify the
> computational region (i.e. when you go from a given spatial resolution
> to a coarser one)?
> Did you try to resample a raster data set and wonder how the new cell's
> value is computed? Which module did you try to use? Which methods?
> Vector data points? Which interpolation module did you try?
> Nikos
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190310/0be96a10/attachment-0001.html>
