[GRASS-user] v.net.distance - from feature was not reachable
Daniel McInerney daniel.o.mcinerney at gmail.com
Wed Nov 20 09:37:36 PST 2019
Hi List,
We are using v.net.distance to calculate the shortest path between two
points on a river network, but have been experiencing some issues in
both grass 7.4 and 7.9. In some instances, we need to add a new vector
line (stream) to the river network, which we have done using v.patch as
follows:
v.patch input=river_network,stream output=river_network_with_stream
We then clean the output as follows:
v.clean input=river_network_with_stream
output=river_network_with_stream_clean tool=rmdupl,break,snap
We then run the following steps to calculate the shortest path (based on
the documentation [1]), where the vector dataset (start_point) is
located on the above-mentioned stream and the end_point is located on
the river network:
v.net input=river_network_with_stream_clean points=start_point
output=river_net operation=connect thresh=100 arc_layer=1 node_layer=2
--overwrite
v.net input=river_net points=end_point output=river_net2
operation=connect thresh=100 arc_layer=1 node_layer=3 --overwrite
The resulting output of v.category is:
  v.category input=river_net2 option=report
Layer: 1
type       count        min        max
point          0          0          0
line      102092          1     102072
boundary       0          0          0
centroid       0          0          0
area           0          0          0
face           0          0          0
kernel         0          0          0
all       102092          1     102072
Layer: 2
type       count        min        max
point          1          1          1
line           0          0          0
boundary       0          0          0
centroid       0          0          0
area           0          0          0
face           0          0          0
kernel         0          0          0
all            1          1          1
Layer: 3
type       count        min        max
point          1          1          1
line           0          0          0
boundary       0          0          0
centroid       0          0          0
area           0          0          0
face           0          0          0
kernel         0          0          0
all            1          1          1
At this point, I visually confirm that both points are connected to the
network and then run:
v.net.distance in=river_net2 out=river_path from_layer=2 to_layer=3
--overwrite
However, I (keep) get a warning ( WARNING: 1 'from' feature was not
reachable) and the output is empty. I have read a few posts online
reporting the same issue, but none of the proposed solutions have
helped. Is there a step that I am overlooking as I would have assumed
that once the network topology is built and the points are connected to
the network that it would have run correctly. I confirm that I can
calculate the shortest path when I use a start point that is the river
network (excluding the stream), so I am assuming that the issue is
related to the output of the v.patch?
Thanks in advance for any help or suggestions.
best regards,
Daniel.
[1]: https://grass.osgeo.org/grass76/manuals/v.net.distance.html
