[GRASS-user] Can I turn off compression
Ken Mankoff
mankoff at gmail.com
Sat Feb 29 08:40:20 PST 2020
Hm. Answer: No
I just did:
export GRASS_COMPRESSOR=none
And then get this error message:
WARNING: No compression is not supported for GRASS raster maps, using default ZLIB
Seems like a shame to not have this as an option. I'll try speeding it up by tweaking the compression method and amount.
-k.
On 2020-02-29 at 08:37 -08, Ken Mankoff <mankoff at gmail.com> wrote...
> Hi,
> I'd like to turn off compression for all maps. Is this possible with
> g.gisenv or environment variables? The g.gisenv manual only shows how
> to choose among compression methods, not disable it.
> This does not seem to work:
> g.gisenv set="GRASS_COMPRESSOR=none" # optimize for speed
> I can decompress one map with:
> r.compress -u map=foo
> But I'm trying to skip the time spent compressing and decompressing
> altogether. I could use a small speed boost, and this seems like an
> easy way to speed things up - I can afford the disk space for all the
> temporary intermediate maps.
> Thanks,
> -k.
