[GRASS-user] Error trying to export a database table
Moritz Lennert
mlennert at club.worldonline.be
Fri Dec 3 06:18:02 PST 2021
Hi Tom,
Note that if all you want is to create a CSV file from the attribute table, v.db.select can do the job for you. In GRASS 8 it actually has a format parameter that lets you choose CSV explicitly, but even without that you can get a satisfying result.
Moritz
Le 3 décembre 2021 13:48:58 GMT+01:00, Thomas Adams <tea3rd at gmail.com> a écrit :
>Hi Veronica!
>Thank you for your response and the information. At least I know that I am
>not doing anything wrong …
>Best,
>Tom
>On Fri, Dec 3, 2021 at 6:14 AM Veronica Andreo <veroandreo at gmail.com> wrote:
>> Hello Tom
>> It is the same error as reported here:
>> https://lists.osgeo.org/pipermail/grass-dev/2021-November/095454.html
>> I have encountered it myself but it's not clear where it comes from. It
>> happens in only one location (an old latlong one) and I can't reproduce
>> with other locations. I use Fedora Linux.
>> Sorry for not being of more help.
>> Vero
>> El jue, 2 dic 2021 a las 19:40, Thomas Adams (<tea3rd at gmail.com>)
>> escribió:
>>> Hi all:
>>> I'm using GRASS on a Mac:
>>> GRASS version: 7.8.6dev
>>> Code revision: 0d636df8f
>>> Build date: 2021-09-09
>>> Build platform: x86_64-apple-darwin20.6.0
>>> GDAL: 3.1.4
>>> PROJ: 7.1.1
>>> GEOS: 3.8.1
>>> SQLite: 3.35.4
>>> Python: 3.8.8
>>> wxPython: 4.1.1
>>> Platform: macOS-10.16-x86_64-i386-64bit
>>> I get an error trying to export a database table using…
>>> db.out.ogr --overwrite input=CEATI_dams_not_RR_gauge_rfc_fcst at teaiii
>>> output=/Users/teaiii/CEATI_dams_not_RR_gauge_rfc_fcst format=CSV
>>> table=CEATI_dams_not_RR_gauge_rfc_fcst
>>> ERROR:
>>> GRASS 7.8.6dev (global-dataset):~ >
>>> <fcst at teaiii output=/Users/teaiii/CEATI_dams_not_RR_gauge_rfc_fcst
>>> format=CSV table=CEATI_dams_not_RR_gauge_rfc_fcst
>>> WARNING: The combination of types is not supported by all formats.
>>> ERROR 10: Pointer 'hSRS' is NULL in 'OSRImportFromWkt'.
>>> ERROR: Unable to create OGR spatial reference
>>> ERROR: Module <v.out.ogr> failed
>>> This happens using with the GRASS GUI or from the command line.
>>> Any suggestions?
>>> Regards,
>>> Tom
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20211203/447665b8/attachment-0001.html>
