[GRASS-user] Error trying to export a database table
Thomas Adams
tea3rd at gmail.com
Fri Dec 3 06:57:36 PST 2021
Hi Moritz!
Thank you so much! That's a great idea… oddly enough, after you mention
this, I remember seeing this for v.db.select.
Thanks again!
Best,
Tom
On Fri, Dec 3, 2021 at 9:18 AM Moritz Lennert <mlennert at club.worldonline.be>
wrote:
> Hi Tom,
> Note that if all you want is to create a CSV file from the attribute
> table, v.db.select can do the job for you. In GRASS 8 it actually has a
> format parameter that lets you choose CSV explicitly, but even without that
> you can get a satisfying result.
> Moritz
> Le 3 décembre 2021 13:48:58 GMT+01:00, Thomas Adams <tea3rd at gmail.com> a
> écrit :
>> Hi Veronica!
>> Thank you for your response and the information. At least I know that I
>> am not doing anything wrong …
>> Best,
>> Tom
>> On Fri, Dec 3, 2021 at 6:14 AM Veronica Andreo <veroandreo at gmail.com>
>> wrote:
>>> Hello Tom
>>> It is the same error as reported here:
>>> https://lists.osgeo.org/pipermail/grass-dev/2021-November/095454.html
>>> I have encountered it myself but it's not clear where it comes from. It
>>> happens in only one location (an old latlong one) and I can't reproduce
>>> with other locations. I use Fedora Linux.
>>> Sorry for not being of more help.
>>> Vero
>>> El jue, 2 dic 2021 a las 19:40, Thomas Adams (<tea3rd at gmail.com>)
>>> escribió:
>>>> Hi all:
>>>> I'm using GRASS on a Mac:
>>>> GRASS version: 7.8.6dev
>>>> Code revision: 0d636df8f
>>>> Build date: 2021-09-09
>>>> Build platform: x86_64-apple-darwin20.6.0
>>>> GDAL: 3.1.4
>>>> PROJ: 7.1.1
>>>> GEOS: 3.8.1
>>>> SQLite: 3.35.4
>>>> Python: 3.8.8
>>>> wxPython: 4.1.1
>>>> Platform: macOS-10.16-x86_64-i386-64bit
>>>> I get an error trying to export a database table using…
>>>> db.out.ogr --overwrite input=CEATI_dams_not_RR_gauge_rfc_fcst at teaiii
>>>> output=/Users/teaiii/CEATI_dams_not_RR_gauge_rfc_fcst format=CSV
>>>> table=CEATI_dams_not_RR_gauge_rfc_fcst
>>>> ERROR:
>>>> GRASS 7.8.6dev (global-dataset):~ >
>>>> <fcst at teaiii output=/Users/teaiii/CEATI_dams_not_RR_gauge_rfc_fcst
>>>> format=CSV table=CEATI_dams_not_RR_gauge_rfc_fcst
>>>> WARNING: The combination of types is not supported by all formats.
>>>> ERROR 10: Pointer 'hSRS' is NULL in 'OSRImportFromWkt'.
>>>> ERROR: Unable to create OGR spatial reference
>>>> ERROR: Module <v.out.ogr> failed
>>>> This happens using with the GRASS GUI or from the command line.
>>>> Any suggestions?
>>>> Regards,
>>>> Tom
>>>> _______________________________________________
>>>> grass-user mailing list
>>>> grass-user at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20211203/8469a862/attachment.html>
