[GRASS-user] Loading LPC data in GRASS
Maris Nartiss maris.gis at gmail.com
Tue Mar 23 23:01:04 PDT 2021
Hello Andreas,
r.in.pdal still lacks metadata printing functionality and thus has not
been merged into the main branch yet. You can get the code from this
PR: https://github.com/OSGeo/grass/pull/1200
Let us know if there are any problems with r.in.pdal.
Best,
Māris.
2021-03-24 0:11 GMT+02:00, Andreas Yankopolus <andreas at yank.to>:
> I’m starting to work with LiDAR point cloud (LPC) data with the goal of
> creating multi-band rasters that list terrain height, surface height, and
> surface type. GRASS looks like the ticket for visualizing LPC data and
> processing it into GeoTIFFs using Python scripting.
> I’m on Ubuntu 20.04, and it appears that LPC support requires compiling your
> own binary, which I did from the GitHub repo following these instructions:
> https://grasswiki.osgeo.org/wiki/Compile_and_Install_Ubuntu
> <https://grasswiki.osgeo.org/wiki/Compile_and_Install_Ubuntu>
> The resulting 7.9.dev binary has v.in.pdal but not r.in.pdal. Is there a way
> to get the latter working? All the tutorials I’m finding refer to
> r.in.lidar, which appears similar to r.in.pdal but relies on deprecated
> liblas instead of pdal.
> Looks like d.vect will get me from a vector layer to a raster layer but
> haven’t figured it out yet. Should I import using v.in.pdal then convert to
> raster with d.vect?
> Thanks,
> Andreas
