[GRASS-user] v.in.ogr ESRI fileGDB
Paulo van Breugel p.vanbreugel at gmail.com
Fri Sep 17 07:17:35 PDT 2021
And if it works, perhaps it is worth adding an example to the help page? Or
send a working code example that others can add to the help file of
v.in.ogr if you like.
On Fri, Sep 17, 2021 at 8:46 AM Maris Nartiss <maris.gis at gmail.com> wrote:
> Hello Rich,
> I don't have File GDB at hand to test it but it should be as simple as
> pointing "input" to the folder of FGDB and setting "layer" to the name
> of dataset in FGDB. You can get names of all layers in CLI with
> "ogrinfo -ro -so /path/to/FGDB".
> Good luck & let us know if you succeed.
> Māris.
> ceturtd., 2021. g. 16. sept., plkst. 20:08 — lietotājs Rich Shepard
> (<rshepard at appl-ecosys.com>) rakstīja:
> > I have an ESRI GDB directory of bathymetric and topographic coverage.
> I've
> > not before imported this type of file from the command line.
> > Looking at the v.in.ogr manual page I'm not sure how to write the
> command;
> > there's not an example for a GDB.
> > Please point me to a reference that will teach me how to import this file
> > type.
> > TIA,
> > Rich
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20210917/54362794/attachment.html>
