[GRASS-user] v.in.ogr ESRI fileGDB
    Rich Shepard
    rshepard at appl-ecosys.com
    Fri Sep 17 08:30:18 PDT 2021
On Fri, 17 Sep 2021, Maris Nartiss wrote:
> I don't have File GDB at hand to test it but it should be as simple as
> pointing "input" to the folder of FGDB and setting "layer" to the name of
> dataset in FGDB. You can get names of all layers in CLI with "ogrinfo -ro
> -so /path/to/FGDB".
Māris,
Something's wrong here. Using 'ogrinfo -ro -so Tile_E.gdb' from the
directory where that's located produces this message:
INFO: Open of `Tile_E.gdb/'
       using driver `OpenFileGDB' successful.
Same result using -al rather than -ro.
Using the GUI:
Fri Sep 17 08:20:46 2021)
v.in.ogr -r input=~/projects/washington/nevins-dock/data/bathymetry/Tile_E.gdb output=bathy_terrain
ERROR: Unable to open data source <[path_to_/Tile_E.gdb>
Is it me or v.in.ogr in the 8.0dev source?
A couple of years ago I had no problems importing ESRI FileGDB maps.
Regards,
Rich
