[GRASS-user] v.in.ogr ESRI fileGDB
    Maris Nartiss
    maris.gis at gmail.com
    Fri Sep 17 08:53:22 PDT 2021
Strange. I just tested and it works just as I described:
v.in.ogr input=/home/maris/path/to/dataset.gdb/ layer=mylayer output=mylayer
I was testing on the main branch compiled at the end of August running
with GDAL 3.0.4.
Rich, you should see in the output of ogrinfo -ro -so a list of layers
in the FGDB. If you do not see them, then you will not be able to
import as GRASS is using OGR for reading FGDB.
Here's an example of output on my system:
ogrinfo -ro -so path/to.gdb/
INFO: Open of `to.gdb/'
      using driver `OpenFileGDB' successful.
1: first_layer (Multi Line String)
2: second_layer (Multi Polygon)
Māris.
piektd., 2021. g. 17. sept., plkst. 18:30 — lietotājs Rich Shepard
(<rshepard at appl-ecosys.com>) rakstīja:
> On Fri, 17 Sep 2021, Maris Nartiss wrote:
> > I don't have File GDB at hand to test it but it should be as simple as
> > pointing "input" to the folder of FGDB and setting "layer" to the name of
> > dataset in FGDB. You can get names of all layers in CLI with "ogrinfo -ro
> > -so /path/to/FGDB".
> Māris,
> Something's wrong here. Using 'ogrinfo -ro -so Tile_E.gdb' from the
> directory where that's located produces this message:
> INFO: Open of `Tile_E.gdb/'
> Same result using -al rather than -ro.
> Using the GUI:
> Fri Sep 17 08:20:46 2021)
> v.in.ogr -r input=~/projects/washington/nevins-dock/data/bathymetry/Tile_E.gdb output=bathy_terrain
> ERROR: Unable to open data source <[path_to_/Tile_E.gdb>
> Is it me or v.in.ogr in the 8.0dev source?
> A couple of years ago I had no problems importing ESRI FileGDB maps.
> Regards,
> Rich
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
