[GRASS-user] v.in.ascii syntax help needed
Maris Nartiss
maris.gis at gmail.com
Mon May 8 22:32:23 PDT 2023
On the first row you have specified a line with 5 coordinates and one
category (L 5 1).
You have not provided the last line containing that one category. Just
add „1 1“ (layer 1, cat 1) as a last row and you should be fine.
Māris.
pirmd., 2023. g. 8. maijs, plkst. 23:59 — lietotājs Rich Shepard
(<rshepard at appl-ecosys.com>) rakstīja:
> The v.in.ascii manual has an exmple of a standard input file with
> elevations. I want to import a rectangle defining the analysis area mask. My
> input file has a syntax error and I don't see what it is when I examine the
> manual page.
> Input file:
> L 5 1
> 2306066.31 224201.00
> 2307121.58 224201.00
> 2307121.58 223165.80
> 2306066.31 223165.80
> 2306066.31 224401.00
> Grass error message:
> GRASS Oregon/analysis_area:analyses > v.in.ascii -zn in=$HOME/projects/oregon/northside-rock/data/analysis-area.txt out=anal_mask format=standard columns='x double precision, y double precision,' x=1 y=2 cat=0 --o
> WARNING: End of ASCII file reached before end of categories
> ERROR: Import failed
> If I remove the cat=0 option I trigger the same error.
> TIA,
> Rich
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
