[GRASSweb-list]markus: web/gdp/grassmanuals grass50_commands_sorted.html,1.1.1.1,1.2
grass at intevation.de grass at intevation.de
Sat Aug 24 01:54:21 EDT 2002
Author: markus
Update of /grassrepository/web/gdp/grassmanuals
In directory doto:/tmp/cvs-serv13400
Modified Files:
Log Message:
fixed DEFANGED (introduced by email Sanitizer)
Index: grass50_commands_sorted.html
RCS file: /grassrepository/web/gdp/grassmanuals/grass50_commands_sorted.html,v
retrieving revision 1.1.1.1
retrieving revision 1.2
diff -u -d -r1.1.1.1 -r1.2
--- grass50_commands_sorted.html	24 Nov 2001 18:28:01 -0000	1.1.1.1
+++ grass50_commands_sorted.html	24 Aug 2002 05:54:19 -0000	1.2
@@ -1,10 +1,10 @@
 <html>
 <head>
-<DEFANGED_meta name="generator" content="Corel WordPerfect 10">
-<DEFANGED_meta http-equiv="content-Type" content="text/html; charset=utf-8">
+<DEFANGED_meta name="generator" content="Corel WordPerfect 10">
+<DEFANGED_meta http-equiv="content-Type" content="text/html; charset=utf-8">
- <!-- <DEFANGED_STYLE>
+ <!--  <!-- <DEFANGED_STYLE>
 p
[...1519 lines suppressed...]
 files, which are stored in the database, define text information for printing
 with p.map and for graphics display with d.paint.labels.</span></span></p>
-<p DEFANGED_STYLE="text-indent: -1.5in; margin-left: 1.5in"><span DEFANGED_STYLE="font-family: 'Arial', sans-serif"><span DEFANGED_STYLE="font-size: 11pt">p.map<span>&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;</span>Use a file of mapping instructions to produce a printout</span></span></p>
-<p DEFANGED_STYLE="text-indent: -1.5in; margin-left: 1.5in"><span DEFANGED_STYLE="font-family: 'Arial', sans-serif"><span DEFANGED_STYLE="font-size: 11pt">p.map.new<span>&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;</span>Use a file of mapping instructions to produce a printout</span></span></p>
-<p DEFANGED_STYLE="text-indent: -1.5in; margin-left: 1.5in"><span DEFANGED_STYLE="font-family: 'Arial', sans-serif"><span DEFANGED_STYLE="font-size: 11pt">p.ppm<span>&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;</span>Reads portable pixmap (ppm) files created by PPM utilities</span></span></p>
-<p DEFANGED_STYLE="text-indent: -1.5in; margin-left: 1.5in"><span DEFANGED_STYLE="font-family: 'Arial', sans-serif"><span DEFANGED_STYLE="font-size: 11pt">p.select<span>&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;</span>Select a printer from the printer list</span></span></p>
-<p><span DEFANGED_STYLE="font-family: 'Arial', sans-serif"><span DEFANGED_STYLE="font-size: 11pt">ps.icon<span>&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;</span>Creates and modifies icons for use with ps.map</span></span></p>
-<p DEFANGED_STYLE="text-indent: -1.5in; margin-left: 1.5in"><span DEFANGED_STYLE="font-family: 'Arial', sans-serif"><span DEFANGED_STYLE="font-size: 11pt">ps.map<span>&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;</span>Use a file of mapping instructions to produce a printout on a postscript
+<p DEFANGED_STYLE="text-indent: -1.5in; margin-left: 1.5in"><span DEFANGED_STYLE="font-family: 'Arial', sans-serif"><span DEFANGED_STYLE="font-size: 11pt">p.map<span>&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;</span>Use a file of mapping instructions to produce a printout</span></span></p>
+<p DEFANGED_STYLE="text-indent: -1.5in; margin-left: 1.5in"><span DEFANGED_STYLE="font-family: 'Arial', sans-serif"><span DEFANGED_STYLE="font-size: 11pt">p.map.new<span>&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;</span>Use a file of mapping instructions to produce a printout</span></span></p>
+<p DEFANGED_STYLE="text-indent: -1.5in; margin-left: 1.5in"><span DEFANGED_STYLE="font-family: 'Arial', sans-serif"><span DEFANGED_STYLE="font-size: 11pt">p.ppm<span>&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;</span>Reads portable pixmap (ppm) files created by PPM utilities</span></span></p>
+<p DEFANGED_STYLE="text-indent: -1.5in; margin-left: 1.5in"><span DEFANGED_STYLE="font-family: 'Arial', sans-serif"><span DEFANGED_STYLE="font-size: 11pt">p.select<span>&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;</span>Select a printer from the printer list</span></span></p>
+<p><span DEFANGED_STYLE="font-family: 'Arial', sans-serif"><span DEFANGED_STYLE="font-size: 11pt">ps.icon<span>&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;</span>Creates and modifies icons for use with ps.map</span></span></p>
+<p DEFANGED_STYLE="text-indent: -1.5in; margin-left: 1.5in"><span DEFANGED_STYLE="font-family: 'Arial', sans-serif"><span DEFANGED_STYLE="font-size: 11pt">ps.map<span>&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;</span>Use a file of mapping instructions to produce a printout on a postscript
 printer or to a file</span></span></p>
-<p DEFANGED_STYLE="text-indent: -1.5in; margin-left: 1.5in"><span DEFANGED_STYLE="font-family: 'Arial', sans-serif"><span DEFANGED_STYLE="font-size: 11pt">ps.select<span>&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;</span>Select a postscript device for GRASS hardcopy output</span></span></p>
+<p DEFANGED_STYLE="text-indent: -1.5in; margin-left: 1.5in"><span DEFANGED_STYLE="font-family: 'Arial', sans-serif"><span DEFANGED_STYLE="font-size: 11pt">ps.select<span>&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;</span>Select a postscript device for GRASS hardcopy output</span></span></p>
 <br>
 <br>
 <br>
More information about the grass-web mailing list
