[GRASSweb-list]New PHP grass website for mirrors without PHP
Markus Neteler neteler at itc.it
Sun Dec 26 14:09:59 EST 2004
Simon,
sorry for the inconvenience. I had added some days before
a file info.php into the images/ subdir to see which
servers do not support PHP. Some people I have contacted
to add support although nearly all mirrors already
have PHP.
It seems that I missed to verify your site and to contact
you in advance - my apologies.
The only PHP function which I am using is include() to
construct the menus. No other tricks...
I can see that your site is functional:
http://gulus.usherbrooke.ca/pub/appl/grass/images/info.php
with PHP3. So nothing to do...
Thanks for supporting the GRASS community.
 Markus
On Tue, Dec 21, 2004 at 04:42:53PM -0500, Simon Valiquette wrote:
> Hello,
>   It is just to tell you that I would have appreciated if you would
> have informed the mirrors in advance that you would need the use of PHP.
>   Actually, my server don't provide PHP.  I will add soon PHP3, but I
> need some time to understand all the security implications for PHP4.  If
> someone compromise my server with a PHP4 security bug, I know some ways
> it can goes undetected, so I need to find a solution.
>   I would also probably need to recompile PHP4 to remove some modules
> (for example ftp and sockets are compiled in by default on Debian, which
> I won't keep if I don't need to).
>   I might have the only server to not offer PHP and perhaps I am too
> paranoid, but my server is located in the same room as one of the main
> 10GE canadian routers that links Montreal, Ottawa, Toronto, Quebec and
> some places in USA, so we do care about security.
>   If there is again an important change in mirroring requirement, it
> will be a good idea to inform the official mirrors.  I hope you do keep
> the mailing adresses of the mirrors.
> Simon Valiquette
> http://gulus.USherbrooke.ca
Markus Neteler     <neteler itc it>       http://mpa.itc.it
ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
More information about the grass-web mailing list
