[GRASS-web] Indian GRASS Mirror site not updating and removed from list
Markus Neteler
neteler at osgeo.org
Thu Jun 19 22:19:17 PDT 2014
Dear Janardhanan Pillai,
the server grass.meteo.uni.wroc.pl is not managed by me but by Paweł
Netzel (in CC). He may check for it. But the issue may be at your end,
please check that your firewall does not block this port:
cat /etc/services | grep rsync
rsync 873/tcp # rsync
rsync 873/udp # rsync
(assuming this since other mirrors can sync from grass.meteo.uni.wroc.pl)
Best regards,
Markus Neteler
On Fri, Jun 20, 2014 at 7:18 AM, Janardhanan Pillai
<jp at ces.iisc.ernet.in> wrote:
> Dear Markus Neteler,
> Looks like the connection from our mirror is rejected by the server. Is
> there any change in server? Please see the response I got when I tried to
> rsync with the server below:
> [root at wgbis ~]# rsync grass.meteo.uni.wroc.pl::
> rsync: failed to connect to grass.meteo.uni.wroc.pl: Connection refused (111)
> rsync error: error in socket IO (code 10) at clientserver.c(122)
> [receiver=3.0.2]
> [root at wgbis ~]# rsync grass.osgeo.org::
> rsync: failed to connect to grass.osgeo.org: Connection refused (111)
> [receiver=3.0.2]
> Please let us know if you could fix this problem at your end. The cron job
> at our end is:
> /usr/bin/rsync -r --delete --times --links grass.meteo.uni.wroc.pl::grass
> /www/html/grass/
> Thanks and with regards,
> jp
> On Thu, June 19, 2014 3:55 pm, Markus Neteler wrote:
>> Dear Uttam,
>> On Thu, Jun 19, 2014 at 9:17 AM, Uttam Kumar <uttam at ces.iisc.ernet.in>
>> wrote:
>>> Indian GRASS Mirror site (http://wgbis.ces.iisc.ernet.in/grass/) is not
>>> updating and shows some old page.
>> Yes, will you be able to fix that?
>>> Also the Indian Mirror site link has
>>> been removed and does not appear in the mirror site list in
>>> http://grass.osgeo.org/mirrors/
>>> Indian mirror site was Tier 1 site initially and it had some problem
>>> since
>>> the new GRASS page was launched.
>> Since all other mirrors are updating without problems, it may be an
>> issue at wgbis.ces.iisc.ernet.in.
>>> Please see to it and let us know how to solve the problem.
>> Please check the error logs on your server and possibly check if you
>> have local filters in place.
>> best regards,
>> Markus Neteler
>> This message has been scanned for viruses and
>> dangerous content by MailScanner, and is
>> believed to be clean.
> Janardhanan Pillai
> Technical Officer
> Centre for Ecological Sciences
> Indian Institute of Science
> Bangalore - 560012
> Phone: +91-80-2293 3106
More information about the grass-web
