[GRASS-web] Indian GRASS Mirror site not updating and removed from list
Janardhanan Pillai
jp at ces.iisc.ernet.in
Thu Jun 19 22:38:03 PDT 2014
Dear Markus Neteler,
Thanks for the quick reply. The service rsync is, of course open at our
server. I would like to hear from Pawel if the rsync request from our
server was rejected at your end. If the request did not reach your end,
please let me know so that I could take it up with the proxy admin of our
campus.
Thanks and with regards,
jp
On Fri, June 20, 2014 10:49 am, Markus Neteler wrote:
> Dear Janardhanan Pillai,
> the server grass.meteo.uni.wroc.pl is not managed by me but by PaweÅ
> Netzel (in CC). He may check for it. But the issue may be at your end,
> please check that your firewall does not block this port:
> cat /etc/services | grep rsync
> rsync 873/tcp # rsync
> rsync 873/udp # rsync
> (assuming this since other mirrors can sync from grass.meteo.uni.wroc.pl)
> Best regards,
> Markus Neteler
> On Fri, Jun 20, 2014 at 7:18 AM, Janardhanan Pillai
>> Looks like the connection from our mirror is rejected by the server. Is
>> there any change in server? Please see the response I got when I tried
>> to
>> rsync with the server below:
>> [root at wgbis ~]# rsync grass.meteo.uni.wroc.pl::
>> rsync: failed to connect to grass.meteo.uni.wroc.pl: Connection refused
>> (111)
>> rsync error: error in socket IO (code 10) at clientserver.c(122)
>> [receiver=3.0.2]
>> [root at wgbis ~]# rsync grass.osgeo.org::
>> rsync: failed to connect to grass.osgeo.org: Connection refused (111)
>> [receiver=3.0.2]
>> Please let us know if you could fix this problem at your end. The cron
>> job
>> at our end is:
>> /usr/bin/rsync -r --delete --times --links
>> grass.meteo.uni.wroc.pl::grass
>> /www/html/grass/
>> jp
>> On Thu, June 19, 2014 3:55 pm, Markus Neteler wrote:
>>> Dear Uttam,
>>> On Thu, Jun 19, 2014 at 9:17 AM, Uttam Kumar <uttam at ces.iisc.ernet.in>
>>> wrote:
>>>> Indian GRASS Mirror site (http://wgbis.ces.iisc.ernet.in/grass/) is
>>>> not
>>>> updating and shows some old page.
>>> Yes, will you be able to fix that?
>>>> Also the Indian Mirror site link has
>>>> been removed and does not appear in the mirror site list in
>>>> http://grass.osgeo.org/mirrors/
>>>> Indian mirror site was Tier 1 site initially and it had some problem
>>>> since
>>>> the new GRASS page was launched.
>>> Since all other mirrors are updating without problems, it may be an
>>> issue at wgbis.ces.iisc.ernet.in.
>>>> Please see to it and let us know how to solve the problem.
>>> Please check the error logs on your server and possibly check if you
>>> have local filters in place.
>>> best regards,
>>> Markus Neteler
>>> This message has been scanned for viruses and
>>> dangerous content by MailScanner, and is
>>> believed to be clean.
>> Janardhanan Pillai
>> Technical Officer
>> Centre for Ecological Sciences
>> Indian Institute of Science
>> Bangalore - 560012
>> Phone: +91-80-2293 3106
Janardhanan Pillai
Technical Officer
Bangalore - 560012
More information about the grass-web
