[GRASS-web] Indian GRASS Mirror site not updating and removed from list
Janardhanan Pillai
jp at ces.iisc.ernet.in
Fri Jun 20 02:19:20 PDT 2014
Dear Paweł Netzel,
The rsync is open on our server and I got the info from our proxy admin
that rsync is not blocked at the proxy, but I get the connected refused
error when our server do an rsync with grass.meteo.uni.wroc.pl. So I
assume that the rejection comes from your server. Could you please look
into it?
Thanks and with regards,
jp
On Fri, June 20, 2014 10:49 am, Markus Neteler wrote:
> Dear Janardhanan Pillai,
> the server grass.meteo.uni.wroc.pl is not managed by me but by PaweÅ
> Netzel (in CC). He may check for it. But the issue may be at your end,
> please check that your firewall does not block this port:
> cat /etc/services | grep rsync
> rsync 873/tcp # rsync
> rsync 873/udp # rsync
> (assuming this since other mirrors can sync from grass.meteo.uni.wroc.pl)
> Best regards,
> Markus Neteler
> On Fri, Jun 20, 2014 at 7:18 AM, Janardhanan Pillai
> <jp at ces.iisc.ernet.in> wrote:
>> Dear Markus Neteler,
>> Looks like the connection from our mirror is rejected by the server. Is
>> there any change in server? Please see the response I got when I tried
>> to
>> rsync with the server below:
>> [root at wgbis ~]# rsync grass.meteo.uni.wroc.pl::
>> rsync: failed to connect to grass.meteo.uni.wroc.pl: Connection refused
>> (111)
>> rsync error: error in socket IO (code 10) at clientserver.c(122)
>> [receiver=3.0.2]
>> [root at wgbis ~]# rsync grass.osgeo.org::
>> rsync: failed to connect to grass.osgeo.org: Connection refused (111)
>> [receiver=3.0.2]
>> Please let us know if you could fix this problem at your end. The cron
>> job
>> at our end is:
>> /usr/bin/rsync -r --delete --times --links
>> grass.meteo.uni.wroc.pl::grass
>> /www/html/grass/
>> jp
>> On Thu, June 19, 2014 3:55 pm, Markus Neteler wrote:
>>> Dear Uttam,
>>> On Thu, Jun 19, 2014 at 9:17 AM, Uttam Kumar <uttam at ces.iisc.ernet.in>
>>> wrote:
>>>> Indian GRASS Mirror site (http://wgbis.ces.iisc.ernet.in/grass/) is
>>>> not
>>>> updating and shows some old page.
>>> Yes, will you be able to fix that?
>>>> Also the Indian Mirror site link has
>>>> been removed and does not appear in the mirror site list in
>>>> http://grass.osgeo.org/mirrors/
>>>> Indian mirror site was Tier 1 site initially and it had some problem
>>>> since
>>>> the new GRASS page was launched.
>>> Since all other mirrors are updating without problems, it may be an
>>> issue at wgbis.ces.iisc.ernet.in.
>>>> Please see to it and let us know how to solve the problem.
>>> Please check the error logs on your server and possibly check if you
>>> have local filters in place.
>>> best regards,
>>> Markus Neteler
>>> This message has been scanned for viruses and
>>> dangerous content by MailScanner, and is
>>> believed to be clean.
>> Janardhanan Pillai
>> Technical Officer
>> Centre for Ecological Sciences
>> Indian Institute of Science
>> Bangalore - 560012
>> Phone: +91-80-2293 3106
Janardhanan Pillai
Technical Officer
Bangalore - 560012
More information about the grass-web
