[GRASS-web] Action Required: Indian GRASS Mirror site not updating and removed from list
Uttam Kumar
uttam at ces.iisc.ernet.in
Tue Jun 24 11:32:12 PDT 2014
Dear Pawel,
You must have seen the previous mail from Markus and JP reagarding the
Indian GRASS Mirror site not updating.
We have checked from our side (the server) and looks like things are fine.
Please look at the the grass.meteo.uni.wroc.pl and check the log if it is
rejecting the request from our server
(http://wgbis.ces.iisc.ernet.in/grass).
Waiting for you early response.
Uttam.
> Dear Paweł Netzel,
> The rsync is open on our server and I got the info from our proxy admin
> that rsync is not blocked at the proxy, but I get the connected refused
> error when our server do an rsync with grass.meteo.uni.wroc.pl. So I
> assume that the rejection comes from your server. Could you please look
> into it?
> Thanks and with regards,
> jp
> On Fri, June 20, 2014 10:49 am, Markus Neteler wrote:
>> Dear Janardhanan Pillai,
>> the server grass.meteo.uni.wroc.pl is not managed by me but by PaweÅ
>> Netzel (in CC). He may check for it. But the issue may be at your end,
>> please check that your firewall does not block this port:
>> cat /etc/services | grep rsync
>> rsync 873/tcp # rsync
>> rsync 873/udp # rsync
>> (assuming this since other mirrors can sync from
>> grass.meteo.uni.wroc.pl)
>> Best regards,
>> Markus Neteler
>> On Fri, Jun 20, 2014 at 7:18 AM, Janardhanan Pillai
>> <jp at ces.iisc.ernet.in> wrote:
>>> Dear Markus Neteler,
>>> Looks like the connection from our mirror is rejected by the server. Is
>>> there any change in server? Please see the response I got when I tried
>>> to
>>> rsync with the server below:
>>> [root at wgbis ~]# rsync grass.meteo.uni.wroc.pl::
>>> rsync: failed to connect to grass.meteo.uni.wroc.pl: Connection refused
>>> (111)
>>> rsync error: error in socket IO (code 10) at clientserver.c(122)
>>> [receiver=3.0.2]
>>> [root at wgbis ~]# rsync grass.osgeo.org::
>>> rsync: failed to connect to grass.osgeo.org: Connection refused (111)
>>> [receiver=3.0.2]
>>> Please let us know if you could fix this problem at your end. The cron
>>> job
>>> at our end is:
>>> /usr/bin/rsync -r --delete --times --links
>>> grass.meteo.uni.wroc.pl::grass
>>> /www/html/grass/
>>> jp
>>> On Thu, June 19, 2014 3:55 pm, Markus Neteler wrote:
>>>> Dear Uttam,
>>>> On Thu, Jun 19, 2014 at 9:17 AM, Uttam Kumar <uttam at ces.iisc.ernet.in>
>>>> wrote:
>>>>> Indian GRASS Mirror site (http://wgbis.ces.iisc.ernet.in/grass/) is
>>>>> not
>>>>> updating and shows some old page.
>>>> Yes, will you be able to fix that?
>>>>> Also the Indian Mirror site link has
>>>>> been removed and does not appear in the mirror site list in
>>>>> http://grass.osgeo.org/mirrors/
>>>>> Indian mirror site was Tier 1 site initially and it had some problem
>>>>> since
>>>>> the new GRASS page was launched.
>>>> Since all other mirrors are updating without problems, it may be an
>>>> issue at wgbis.ces.iisc.ernet.in.
>>>>> Please see to it and let us know how to solve the problem.
>>>> Please check the error logs on your server and possibly check if you
>>>> have local filters in place.
>>>> best regards,
>>>> Markus Neteler
>>>> This message has been scanned for viruses and
>>>> dangerous content by MailScanner, and is
>>>> believed to be clean.
>>> Janardhanan Pillai
>>> Technical Officer
>>> Centre for Ecological Sciences
>>> Indian Institute of Science
>>> Bangalore - 560012
>>> Phone: +91-80-2293 3106
> Janardhanan Pillai
> Technical Officer
> Bangalore - 560012
More information about the grass-web
