[winGRASS] m.proj fails in wingrass?
Bob Sandefur
rls at pincock.com
Fri Jun 8 11:49:20 EDT 2001
Hi-
I am running 2000 pro upgraded by microsoft on 7-jun-2001 and
cygwin from autoupdate dated 1-may-2001 using
May 17 09:56 cygwin-1.3.1-1.tar.gz
May 17 09:33 setup.exe
(I assume there is a cygwin command to get version info but I don't what it is)
thanx
bob
>>> Andreas Lange <Andreas.Lange at Rhein-Main.de> 06/08/01 09:03AM >>>
Hi Bob,
could you please tell me the following:
- which cygwin version do you use? (release of cygwin dll)
- which operating system (Windows NT 4.0, 2000 Prof. etc.) you use.
I expirienced many problems with the lates cygwin dll reading and
writing data, so this could explain the problem reading the
ellipse.table and printing the utm values (NaN errors). I have no clue
what this is (library broken in cygwin?) and have no time to fix.
But this seems no GRASS related problem.
HTH,
Andreas
Bob Sandefur wrote:
> Hi
> I am using wingrass from grass5.0.0pre1_i686-pc-cygwin_bin.tar.gz and get a m.proj failure as shown at bottom of this email. However the linux version works fine.
> Can anyone else get m.proj to fail?
> thanx
> Robert L Sandefur (Bob)
> Principal Geostatistician
> Pincock Allen & Holt (A Hart Crowser Company)
> International Minerals Consultants
> 274 Union Suite 200
> Lakewood CO 80228
> USA
> 303 914-4467 v
> 303 987-8907 f
> Coordinate Conversions
> 1- Conversion 2- Input/Output Selection
> 3- Quit
> Enter your selection [3] : 1
> Initializing INPUT PROJECTION:
> Please specify projection name
> Enter 'list' for the list of available projections
> Hit RETURN to cancel request
> >ll
> Initializing OUTPUT PROJECTION:
> >utm
> Initializing OUTPUT projection ELLIPSOID:WARNING: Lines 34, 37, 38, 40, 42, 4 (truncated)
> 59, 64, 66, 72,
> 78, 80, 82, 84, 86, 88, 90, 96, 98, 103, 105, 107, 109, 111, 113,
> 115, 120, 122, 126, 130, 134, 138 of ellipsoid table file
> </usr/local/grass5/etc/ellipse.table> are invalid
> Please specify ellipsoid name
> Enter 'list' for the list of available ellipsoids
> >clark66
> Enter OUTPUT Projection Zone [zone] : 13
> OUTPUT Projection: Would you like to use South Hemisphere (y/[n]) ?
> Enter plural for OUTPUT units [meters]:
> Parameters used in OUTPUT projection:
> +proj=utm +a=63782064.0000000000 +es=0.7500000000 +zone=13 +unfact=1
> Lat/Long->Coord Conversion
> Enter Latitude [dd:mm:ss{N|S}]: 39:00:00N
> Enter Longitude [ddd:mm:ss{E|W}]: 105:00:00W
> Lat/Lon -> Universe Transverse Mercator Conversion:
> Longitude Latitude X (meters) Y (meters)
> 105:01W 39:01N NaN NaN
> winGRASS mailing list
> winGRASS at www.geog.uni-hannover.de
> http://www.geog.uni-hannover.de/mailman/listinfo/wingrass
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange at Rhein-Main.de - A.C.Lange at GMX.net
More information about the grass-windows
