[winGRASS] m.proj fails in wingrass?
Bob Sandefur
rls at pincock.com
Fri Jun 8 12:35:59 EDT 2001
h-
thanx to John Huddleston for cygcheck -v -s
rls at RLS300 /cygdrive/d/cygwin
$ cygcheck -v -s
Cygnus Win95/NT Configuration Diagnostics
Current System Time: Fri Jun 8 10:16:16 2001
WinNT Ver 5.0 build 2195 Service Pack 2
FILE AND PATH STUFF OMMITTED
56k 2000/12/03 d:\cygwin\bin\cygbz21.0.dll - os=4.0 img=1.0 sys=4.0
"cygbz21.0.dll" v0.0 ts=2000/11/20 16:53
45k 2001/04/25 d:\cygwin\bin\cygform5.dll - os=4.0 img=1.0 sys=4.0
"cygform5.dll" v0.0 ts=2001/4/24 23:28
18k 2000/10/23 d:\cygwin\bin\cyggdbm.dll - os=4.0 img=1.0 sys=4.0
"cyggdbm.dll" v0.0 ts=2000/10/22 20:26
17k 2001/01/07 d:\cygwin\bin\cyghistory4.dll - os=4.0 img=1.0 sys=4.0
"cyghistory4.dll" v0.0 ts=2001/1/6 21:34
14k 2000/10/23 d:\cygwin\bin\cygintl.dll - os=4.0 img=1.0 sys=4.0
"cygintl.dll" v0.0 ts=2000/10/23 13:02
81k 2001/04/28 d:\cygwin\bin\cygitcl30.dll - os=4.0 img=1.0 sys=4.0
"cygitcl30.dll" v0.0 ts=2001/4/28 16:57
35k 2001/04/28 d:\cygwin\bin\cygitk30.dll - os=4.0 img=1.0 sys=4.0
"cygitk30.dll" v0.0 ts=2001/4/28 16:57
45k 2000/10/22 d:\cygwin\bin\cygjbig1.dll - os=4.0 img=1.0 sys=4.0
"cygjbig1.dll" v0.0 ts=2000/10/22 17:06
119k 2000/10/23 d:\cygwin\bin\cygjpeg6b.dll - os=4.0 img=1.0 sys=4.0
"cygjpeg6b.dll" v0.0 ts=2000/10/22 18:58
26k 2001/04/25 d:\cygwin\bin\cygmenu5.dll - os=4.0 img=1.0 sys=4.0
"cygmenu5.dll" v0.0 ts=2001/4/24 23:27
156k 2001/04/25 d:\cygwin\bin\cygncurses++5.dll - os=4.0 img=1.0 sys=4.0
"cygncurses++5.dll" v0.0 ts=2001/4/24 23:29
226k 2001/04/25 d:\cygwin\bin\cygncurses5.dll - os=4.0 img=1.0 sys=4.0
"cygncurses5.dll" v0.0 ts=2001/4/24 23:17
15k 2001/04/25 d:\cygwin\bin\cygpanel5.dll - os=4.0 img=1.0 sys=4.0
"cygpanel5.dll" v0.0 ts=2001/4/24 23:27
163k 2001/05/06 d:\cygwin\bin\cygpng2.dll - os=4.0 img=1.0 sys=4.0
"cygpng2.dll" v0.0 ts=2001/5/5 22:05
108k 2001/01/07 d:\cygwin\bin\cygreadline4.dll - os=4.0 img=1.0 sys=4.0
"cygreadline4.dll" v0.0 ts=2001/1/6 21:34
390k 2001/04/28 d:\cygwin\bin\cygtcl80.dll - os=4.0 img=1.0 sys=4.0
"cygtcl80.dll" v0.0 ts=2001/4/28 16:56
5k 2001/04/28 d:\cygwin\bin\cygtclpip80.dll - os=4.0 img=1.0 sys=4.0
10k 2001/04/28 d:\cygwin\bin\cygtclreg80.dll - os=4.0 img=1.0 sys=4.0
"cygtclreg80.dll" v0.0 ts=2001/4/28 16:56
243k 2000/10/23 d:\cygwin\bin\cygtiff3.dll - os=4.0 img=1.0 sys=4.0
"cygtiff3.dll" v0.0 ts=2000/10/22 19:14
623k 2001/04/28 d:\cygwin\bin\cygtk80.dll - os=4.0 img=1.0 sys=4.0
"cygtk80.dll" v0.0 ts=2001/4/28 16:57
424k 2001/01/11 d:\cygwin\bin\cygwinb19.dll - os=4.0 img=1.0 sys=4.0
"cygwin1.dll" v0.0 ts=1998/12/3 21:39
41k 2000/11/20 d:\cygwin\bin\cygXpm-noX4.dll - os=4.0 img=1.0 sys=4.0
"cygXpm-noX4.dll" v0.0 ts=2000/11/19 19:41
45k 2000/11/20 d:\cygwin\bin\cygXpm-X4.dll - os=4.0 img=1.0 sys=4.0
"cygXpm-X4.dll" v0.0 ts=2000/11/19 19:45
49k 2001/02/03 d:\cygwin\bin\cygz.dll - os=4.0 img=1.0 sys=4.0
"cygz.dll" v0.0 ts=2001/2/3 13:35
631k 2001/04/25 d:\cygwin\bin\cygwin1.dll - os=4.0 img=1.0 sys=4.0
"cygwin1.dll" v0.0 ts=2001/4/24 18:01
Cygwin DLL version info:
dll major: 1003
dll minor: 1
dll epoch: 19
dll bad signal mask: 19005
dll old termios: 5
dll malloc env: 28
api major: 0
api minor: 38
shared data: 3
dll identifier: cygwin1
mount registry: 2
cygnus registry name: Cygnus Solutions
cygwin registry name: Cygwin
program options name: Program Options
cygwin mount registry name: mounts v2
cygdrive flags: cygdrive flags
cygdrive prefix: cygdrive prefix
cygdrive default prefix:
build date: Tue Apr 24 20:01:02 EDT 2001
shared id: cygwin1S3
thanx
bob
THEAD FOLLOWS:
----- Original Message -----
To: "Andreas.Lange" <Andreas.Lange at Rhein-Main.de>
Cc: "wingrass" <wingrass at geog.uni-hannover.de>
Sent: Friday, June 08, 2001 9:49 AM
Subject: Re: [winGRASS] m.proj fails in wingrass?
Hi-
I am running 2000 pro upgraded by microsoft on 7-jun-2001 and
cygwin from autoupdate dated 1-may-2001 using
May 17 09:56 cygwin-1.3.1-1.tar.gz
May 17 09:33 setup.exe
(I assume there is a cygwin command to get version info but I don't what it is)
thanx
bob
More information about the grass-windows
