[winGRASS] m.proj fails in wingrass?
    Andreas Lange
    Andreas.Lange at Rhein-Main.de
    Fri Jun  8 17:20:54 EDT 2001
Hi Bob, hi John,
i think that this is the same problem i expirience here too (Win 2000
Prof., latest cygwin dll). Recompiling etc. does not help.
Currently i have not time to spent on Bugfixing cygwin. It must be a
cygwin problem.
If you need map calculating an intermediate fix would be to use proj
4.4.3 directly, the original source code compiles on cygwin, but
installing needs some manual tweeking.
Sorry to be not much of help,
Andreas
Bob Sandefur wrote:
> h-
>  thanx to John Huddleston for cygcheck -v -s
> rls at RLS300 /cygdrive/d/cygwin
> $ cygcheck -v -s
> Cygnus Win95/NT Configuration Diagnostics
> Current System Time: Fri Jun  8 10:16:16 2001
> WinNT Ver 5.0 build 2195 Service Pack 2
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange at Rhein-Main.de - A.C.Lange at GMX.net
More information about the grass-windows
