[winGRASS] m.proj fails in wingrass?
John Huddleston
jhudd at lamar.colostate.edu
Thu Jun 14 13:06:47 EDT 2001
There is a new X11 version xfree-4.1.0 that has been posted to the
pub/cygwin/xfree/xc-4-binaries/4.1.0 area of the ftp section. You
will have to use the ncftp program that comes with cygwin to get
them. The setup.exe (version 1.57) does not get those files on the
download. However, I just cut a cd with contrib, latest, and xfree
and took it home (where I have 28.8 connect) and the new setup.exe
installs the X11 libes. Finally!
Plus, my advice to builders of cygwin distribution tar balls is to
rebuild all the support libraries with the new compiler. That is,
for those libraries that are not supported by Cygwin, move your
/usr/local area out of the way, rename it, try the build, wait until
it fails, find the library it needs, remake it with the new compiler,
and continue until all of GRASS builds. This is how I used to make
the WinGrass distribution. That's why I bundled it as a ZIP files
with the DLLs and the "version" of cygwin binaries. Everything
was binary compatible.
John Huddleston
CSU PhD student
Civil Engineering
----- Original Message -----
To: "John Huddleston" <jhudd at lamar.colostate.edu>
Sent: Wednesday, June 13, 2001 9:17 PM
Subject: RE: [winGRASS] m.proj fails in wingrass?
> Hi John
> Unfortunately, when I upgrade cygwin, d.mon then dies on startup after
> briefly showing a monitor window:
> GRASS:~ > d.mon start=x0
> using default visual which is PseudoColor
> ncolors: 216
> Graphics driver [x0] started
> 0 [main] x0 379 open_stackdumpfile: Dumping stack trace to
> XDRIVER.exe.sta
> ckdump
> ERROR - eof from graphics monitor.
> Problem selecting x0. Will try once more
> Socket is already in use or not accepting connections.
> Cheers
> Mike Thomas.
> > -----Original Message-----
> > From: wingrass-admin at geog.uni-hannover.de
> > [mailto:wingrass-admin at geog.uni-hannover.de]On Behalf Of John Huddleston
> > Sent: Tuesday, 12 June 2001 23:34
> > To: Mike Thomas
> > Cc: wingrass
> > Subject: Re: [winGRASS] m.proj fails in wingrass?
> > Mike,
> > Check the date of your cygwin1.dll If it is the January 2001 version
> > then you will need to upgrade.
> > John Huddleston
> > From: "Mike Thomas" <mthomas at gil.com.au>
> > To: "wingrass" <wingrass at geog.uni-hannover.de>
> > Sent: Monday, June 11, 2001 6:41 PM
> > > Hi Markus.
> > > Thanks for the suggestion.
> > > > > > 115, 120, 122, 126, 130, 134, 138 of ellipsoid table file
> > > > > > </usr/local/grass5/etc/ellipse.table> are invalid
> > > > > This is almost certainly a text/binary mode file read problem.
> > > > I have had
> > > > > simlar problems with other parts of Grass under CYgwin.
> > > > Hi,
> > > > maybe you are using winCVS? In past there was a severe CR/LF
> > problem with
> > > > winCVS. If so, please use another CVS tool.
> > > I use Cygwin's CVS so hopefully this isn't the problem, but I'll look
> > > further into it.
> > > Unfortunately the format of the Cygwin path seems to affect the
> > way files
> > > are treated in general, so it may be that "cvs update" in a double slash
> > > path gives different results to the same command in a directory entered
> > > using the other path format.
> > > When I get a chance to look further into this, I'll pass on the results
> > > (probably not this week).
> > > I have resolved similar problems by modifying the source and
> > rebuilding -
> > > "open ( f, O_BINARY )", rather than "open ( f, 0 )", but
> > unfortunately Grass
> > > has lots of such open calls.
> > > Cheers
> > > Mike Thomas.
> > > _______________________________________________
> > > winGRASS mailing list
> > > winGRASS at www.geog.uni-hannover.de
> > > http://www.geog.uni-hannover.de/mailman/listinfo/wingrass
More information about the grass-windows
